Trying out the latest Gotham release, only to find Neon no longer works for me. Was working under release 9 but seems to be broken in release 10.
Is it me or has anyone else found this.
OK so some positioning change in Gotham messes up the view.
Even if I did fix that, I would also have to fix support for all the new Gotham features which can be quite a bit of work I am not sure I have time for.
At this moment, neon is officially not supported on Gotham.
Ps. If anyone wants to work on it, please be my guest!
Thanks for the reply, hope you find the time in the future. Neon is a nice skin that suits my HTPC.
Just a quick update the problem only resides within Gotham release 10, Neon works fine in release 9. Will try and have a look at what changed between the two.
(2013-12-23, 22:32)TVmine Wrote: [ -> ]Just a quick update the problem only resides within Gotham release 10, Neon works fine in release 9. Will try and have a look at what changed between the two.
Any update if this persists for Gotham release 11 or beyond?
As I was having as much trouble as I was, not only from Neon Skin but other skins I use, I reverted back to fordo. Once Gotham goes beta I will start again and start testing Gotham. Hopefully figuring out what is going wrong with neon.
(2014-02-06, 01:42)TVmine Wrote: [ -> ]As I was having as much trouble as I was, not only from Neon Skin but other skins I use, I reverted back to fordo. Once Gotham goes beta I will start again and start testing Gotham. Hopefully figuring out what is going wrong with neon.
Ok, I would have tested myself, but I'm waiting for the beta or RC release before trying out Gotham.
