My problem is similar. I need Help
Check the log.
18:08:37 T:7708 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:08:37 T:7708 NOTICE: -----------------------------------------------------------------------
18:08:37 T:7708 NOTICE: Starting Kodi (15.2-RC3 Git:20151004-cf72616). Platform: Windows NT x86 32-bit
18:08:37 T:7708 NOTICE: Using Release Kodi x32 build
18:08:37 T:7708 NOTICE: Kodi compiled Oct 4 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
18:08:37 T:7708 NOTICE: Running on Windows 10, kernel: Windows NT x86 64-bit version 10.0
18:08:37 T:7708 NOTICE: Host CPU: Intel® Core i5-2500K CPU @ 3.30GHz, 4 cores available
18:08:37 T:7708 NOTICE: Desktop Resolution: 1360x768 32Bit at 59Hz
18:08:37 T:7708 NOTICE: Running with restricted rights
18:08:37 T:7708 NOTICE: Aero is enabled
18:08:37 T:7708 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
18:08:37 T:7708 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
18:08:37 T:7708 NOTICE: special://masterprofile/ is mapped to: C:\Users\Javier\AppData\Roaming\Kodi\userdata
18:08:37 T:7708 NOTICE: special://home/ is mapped to: C:\Users\Javier\AppData\Roaming\Kodi\
18:08:37 T:7708 NOTICE: special://temp/ is mapped to: C:\Users\Javier\AppData\Roaming\Kodi\cache
18:08:37 T:7708 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
18:08:37 T:7708 NOTICE: Local hostname: PC-Casa
18:08:37 T:7708 NOTICE: Log File is located: C:\Users\Javier\AppData\Roaming\Kodi\kodi.log
18:08:37 T:7708 NOTICE: load settings...
18:08:37 T:8080 NOTICE: Thread CWin32PowerStateWorker start, auto delete: false
18:08:37 T:7708 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
18:08:37 T:7708 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
18:08:37 T:7708 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:08:37 T:7708 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
18:08:37 T:7708 NOTICE: Default DVD Player: dvdplayer
18:08:37 T:7708 NOTICE: Default Video Player: dvdplayer
18:08:37 T:7708 NOTICE: Default Audio Player: paplayer
18:08:37 T:7708 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:08:37 T:7708 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
18:08:37 T:7708 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
18:08:37 T:7708 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:08:37 T:7708 NOTICE: Loaded playercorefactory configuration
18:08:37 T:7708 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:08:37 T:7708 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:08:37 T:4112 NOTICE: Thread ActiveAE start, auto delete: false
18:08:37 T:6588 NOTICE: Thread AESink start, auto delete: false
18:08:37 T:4112 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "LCD-32K30TD** (Dispositivo de High Definition Audio)" seems to be not supported.
18:08:37 T:4112 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "LCD-32K30TD** (Dispositivo de High Definition Audio)" seems to be not supported.
18:08:37 T:4112 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_EAC3" on device "LCD-32K30TD** (Dispositivo de High Definition Audio)" seems to be not supported.
18:08:37 T:4112 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTS" on device "LCD-32K30TD** (Dispositivo de High Definition Audio)" seems to be not supported.
18:08:37 T:4112 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AC3" on device "LCD-32K30TD** (Dispositivo de High Definition Audio)" seems to be not supported.
18:08:37 T:4112 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "LCD-32K30TD** (Dispositivo de High Definition Audio)" seems to be not supported.
18:08:37 T:4112 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_LPCM" on device "LCD-32K30TD** (Dispositivo de High Definition Audio)" seems to be not supported.
18:08:37 T:4112 NOTICE: Found 2 Lists of Devices
18:08:37 T:4112 NOTICE: Enumerated DIRECTSOUND devices:
18:08:37 T:4112 NOTICE: Device 1
18:08:37 T:4112 NOTICE: m_deviceName : {14F89A20-B001-43BA-83E7-47C50694A5E7}
18:08:37 T:4112 NOTICE: m_displayName : SPDIF - Realtek Digital Output(Optical) (Realtek High Definition Audio)
18:08:37 T:4112 NOTICE: m_displayNameExtra: DIRECTSOUND: Realtek Digital Output(Optical) (Realtek High Definition Audio)
18:08:37 T:4112 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
18:08:37 T:4112 NOTICE: m_channels : FL,FR
18:08:37 T:4112 NOTICE: m_sampleRates : 48000
18:08:37 T:4112 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
18:08:37 T:4112 NOTICE: Device 2
18:08:37 T:4112 NOTICE: m_deviceName : {1DF4ECA8-34A3-4271-8053-A17D208D2E70}
18:08:37 T:4112 NOTICE: m_displayName : HDMI - LCD-32K30TD** (Dispositivo de High Definition Audio)
18:08:37 T:4112 NOTICE: m_displayNameExtra: DIRECTSOUND: LCD-32K30TD** (Dispositivo de High Definition Audio)
18:08:37 T:4112 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
18:08:37 T:4112 NOTICE: m_sampleRates : 44100
18:08:37 T:4112 NOTICE: Device 3
18:08:37 T:4112 NOTICE: m_deviceName : default
18:08:37 T:4112 NOTICE: m_displayName : default
18:08:37 T:4112 NOTICE: Device 4
18:08:37 T:4112 NOTICE: m_deviceName : {3A88CB3A-09E7-4A10-88A9-6998494A85C8}
18:08:37 T:4112 NOTICE: m_displayName : SPDIF - Realtek Digital Output (Realtek High Definition Audio)
18:08:37 T:4112 NOTICE: m_displayNameExtra: DIRECTSOUND: Realtek Digital Output (Realtek High Definition Audio)
18:08:37 T:4112 NOTICE: Device 5
18:08:37 T:4112 NOTICE: m_deviceName : {7CDC1099-1D53-4FDE-9343-C1D735709649}
18:08:37 T:4112 NOTICE: m_displayName : Speakers - Altavoces (Realtek High Definition Audio)
18:08:37 T:4112 NOTICE: m_displayNameExtra: DIRECTSOUND: Altavoces (Realtek High Definition Audio)
18:08:37 T:4112 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:08:37 T:4112 NOTICE: Enumerated WASAPI devices:
18:08:37 T:4112 NOTICE: m_displayNameExtra: WASAPI: Realtek Digital Output(Optical) (Realtek High Definition Audio)
18:08:37 T:4112 NOTICE: m_sampleRates : 192000,96000,48000,44100
18:08:37 T:4112 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
18:08:37 T:4112 NOTICE: m_displayNameExtra: WASAPI: LCD-32K30TD** (Dispositivo de High Definition Audio)
18:08:37 T:4112 NOTICE: m_sampleRates : 192000,96000,48000,44100,32000
18:08:37 T:4112 NOTICE: m_dataFormats : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
18:08:37 T:4112 NOTICE: m_displayNameExtra: WASAPI: Realtek Digital Output (Realtek High Definition Audio)
18:08:37 T:4112 NOTICE: m_displayNameExtra: WASAPI: Altavoces (Realtek High Definition Audio)
18:08:37 T:4112 NOTICE: m_channels : FL,FR,FC,LFE,SL,SR,BL,BR
18:08:37 T:4112 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
18:08:37 T:7708 NOTICE: Running database version Addons19
18:08:37 T:7708 NOTICE: ADDONS: Using repository repository.xbmc.org
18:08:37 T:7708 NOTICE: ADDONS: Using repository repository.providerspulsarunofficial
18:08:37 T:7708 NOTICE: ADDONS: Using repository repository.bbtsip.tv
18:08:37 T:7708 NOTICE: ADDONS: Using repository repository.kodiunderground
18:08:37 T:7708 NOTICE: ADDONS: Using repository repository.docshadrach
18:08:37 T:7536 NOTICE: Thread RemoteControl start, auto delete: false
18:08:37 T:7708 NOTICE: Found screen: Generic PnP Monitor on Intel® HD Graphics 3000, adapter 0.
18:08:37 T:7708 NOTICE: Primary mode: 1360x768@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 320x200@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 320x200@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 320x240@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 320x240@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 400x300@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 400x300@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 512x384@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 512x384@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 640x400@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 640x400@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 640x480@ 73.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 640x480@ 75.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 720x480@ 29.97i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 720x480@ 30.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 720x576@ 25.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 720x576@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 720x576@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 800x600@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 800x600@ 72.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1024x768@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1024x768@ 70.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1152x864@ 25.00i - Full Screen
18:08:37 T:7708 NOTICE: Previous line repeats 2 times.
18:08:37 T:7708 NOTICE: Additional mode: 1152x864@ 50.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1152x864@ 29.97i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1152x864@ 30.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1152x864@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1152x864@ 75.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x600@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x600@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x768@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x800@ 25.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x800@ 50.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x800@ 29.97i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x800@ 30.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x800@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x960@ 25.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x960@ 50.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x960@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x960@ 29.97i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x960@ 30.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x1024@ 25.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x1024@ 50.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x1024@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x1024@ 29.97i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x1024@ 30.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1360x768@ 25.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1360x768@ 50.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1360x768@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1360x768@ 29.97i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1360x768@ 30.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1366x768@ 25.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1366x768@ 50.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1366x768@ 29.97i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1366x768@ 30.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1366x768@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1400x1050@ 25.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1400x1050@ 50.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1400x1050@ 29.97i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1400x1050@ 30.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1400x1050@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1400x1050@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1440x900@ 25.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1440x900@ 50.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1440x900@ 29.97i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1440x900@ 30.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1440x900@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1600x900@ 25.00i - Full Screen
18:08:37 T:7708 NOTICE: Previous line repeats 1 times.
18:08:37 T:7708 NOTICE: Additional mode: 1600x900@ 50.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1600x900@ 29.97i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1600x900@ 30.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1600x900@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1600x1200@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1600x1200@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1680x1050@ 25.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1680x1050@ 50.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1680x1050@ 29.97i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1680x1050@ 30.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1920x1080@ 25.00i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
18:08:37 T:7708 NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
18:08:37 T:7708 NOTICE: Checking resolution 16
18:08:37 T:5280 NOTICE: Thread PeripBusCEC start, auto delete: false
18:08:37 T:5052 NOTICE: Thread PeripBusUSB start, auto delete: false
18:08:37 T:7708 NOTICE: Running database version ViewModes6
18:08:37 T:7708 NOTICE: Running database version Textures13
18:08:37 T:7708 NOTICE: Running database version MyMusic52
18:08:37 T:7708 NOTICE: Running database version MyVideos93
18:08:37 T:7708 NOTICE: Running database version TV29
18:08:37 T:7708 NOTICE: Running database version Epg10
18:08:37 T:7708 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
18:08:37 T:7708 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
18:08:37 T:7708 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
18:08:37 T:7708 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
18:08:37 T:6420 NOTICE: Thread LanguageInvoker start, auto delete: false
18:08:37 T:6740 NOTICE: Previous line repeats 3 times.
18:08:37 T:6740 NOTICE: Thread JobWorker start, auto delete: true
18:08:37 T:4808 NOTICE: Thread LanguageInvoker start, auto delete: false
18:08:37 T:7708 NOTICE: initialize done
18:08:37 T:6740 NOTICE: PVRManager - starting up
18:08:37 T:6848 NOTICE: Thread PVRManager start, auto delete: false
18:08:37 T:5460 NOTICE: Thread PVRClient start, auto delete: false
18:08:37 T:5460 NOTICE: AddOnLog: PVR IPTV Simple Client: Playlist file path is not configured. Channels not loaded.
18:08:37 T:7708 NOTICE: Running the application...
18:08:37 T:6420 NOTICE: -->Python Interpreter Initialized<--
18:08:38 T:7708 NOTICE: starting upnp client
18:08:38 T:7708 NOTICE: ES: Starting event server
18:08:38 T:7348 NOTICE: -->Python Interpreter Initialized<--
18:08:38 T:3664 NOTICE: Previous line repeats 3 times.
18:08:38 T:3664 NOTICE: Thread TCPServer start, auto delete: false
18:08:38 T:8040 NOTICE: Thread EventServer start, auto delete: false
18:08:38 T:8040 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:08:38 T:8040 NOTICE: UDP: Listening on port 9777
18:08:38 T:7336 NOTICE: Thread RSSReader start, auto delete: false
18:08:38 T:3880 NOTICE: Thread PVRGUIInfo start, auto delete: false
18:08:38 T:5772 NOTICE: Thread JobWorker start, auto delete: true
18:08:38 T:6848 NOTICE: EPG::CEpgContainer::Start - EPG thread started
18:08:38 T:6496 NOTICE: Thread EPGUpdater start, auto delete: false
18:08:38 T:5504 NOTICE: service.libraryautoupdate-0.9.8 : Update Library Service starting...
18:08:38 T:5504 NOTICE: service.libraryautoupdate-0.9.8 : update timers
18:08:38 T:5504 NOTICE: service.libraryautoupdate-0.9.8 : Creating timer for Video Library
18:08:38 T:6420 NOTICE: [Videoteca2KD - TVGUIA]Update Service starting...
http://www.yaske.cc
18:08:38 T:7348 NOTICE: pelisalacarta.core.config PLATFORM_NAME=kodi-isengard
18:08:38 T:7348 NOTICE: pelisalacarta.core.config runtime path = C:\Users\Javier\AppData\Roaming\Kodi\addons\plugin.video.pelisalacarta
18:08:38 T:7348 NOTICE: pelisalacarta.core.config data path = C:\Users\Javier\AppData\Roaming\Kodi\userdata\addon_data\plugin.video.pelisalacarta\
18:08:38 T:7348 NOTICE: pelisalacarta.core.config temp path = C:\Users\Javier\AppData\Roaming\Kodi\cache\test
18:08:38 T:5564 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.NameError'>
Error Contents: name 're' is not defined
File "C:\Users\Javier\AppData\Roaming\Kodi\addons\script.peliculasaudiolatino2kd\service.py", line 94, in <module>
name_provider = re.sub('.COLOR (.*?)]', '', Addon().getAddonInfo('name').replace('[/COLOR]', ''))
NameError: name 're' is not defined
18:08:38 T:6600 NOTICE: Thread FileCache start, auto delete: false
18:08:39 T:3080 NOTICE: Thread JobWorker start, auto delete: true
18:08:39 T:8056 NOTICE: Previous line repeats 1 times.
18:08:39 T:8056 NOTICE: Thread FileCache start, auto delete: false
18:08:39 T:6740 NOTICE: Previous line repeats 2 times.
18:08:39 T:6740 ERROR: CCurlFile::FillBuffer - Failed: Couldn't resolve host name(6)
18:08:39 T:6740 ERROR: CCurlFile::Open failed with code 0 for
http://repository.bbtsip.tv/repo/addons.xml.md5
18:08:39 T:6740 ERROR: XFILE::CFileCache::Open - failed to open source <http://repository.bbtsip.tv/repo/addons.xml.md5>
18:08:39 T:6740 ERROR: Failed to fetch checksum for directory listing
http://repository.bbtsip.tv/repo/addons.xml for repository repository.bbtsip.tv.
18:08:40 T:5628 NOTICE: Thread FileCache start, auto delete: false
18:08:40 T:6740 NOTICE: Previous line repeats 1 times.
18:08:40 T:6740 ERROR: Failed to read directory listing
http://kodi.speedbox.me/svn_kodi/trunk/addons.xml for repository repository.kodiunderground.
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Coche Policial\Coche Policial.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\The Green Inferno\The Green Inferno.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Marte The Martian\Marte The Martian.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\El Bailarin del desierto\El Bailarin del desierto.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\13 Dies Doctubre\13 Dies Doctubre.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Sicario\Sicario.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Straight Outta Compton\Straight Outta Compton.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Con La Magia En Los Zapatos\Con La Magia En Los Zapatos.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Viaje A Sils Maria\Viaje A Sils Maria.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Song of The Sea\Song of The Sea.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Hot Girls Wanted\Hot Girls Wanted.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Pisandonos Los Tacones!\Pisandonos Los Tacones!.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\El Nino 44\El Nino 44.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Crows 3\Crows 3.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Beasts of No Nation\Beasts of No Nation.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Asesinos Inocentes\Asesinos Inocentes.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Air\Air.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Stand By Me Doraemon\Stand By Me Doraemon.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Wiplala\Wiplala.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Temblores 5 El Legado\Temblores 5 El Legado.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\The Goob\The Goob.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Doble Identidad Jaque Al Mi5\Doble Identidad Jaque Al Mi5.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Road Hard\Road Hard.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Return To Sender\Return To Sender.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Navy Seals Vs Zombies\Navy Seals Vs Zombies.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Yo, El Y Raquel\Yo, El Y Raquel.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Escupire Sobre Tu Tumba 3\Escupire Sobre Tu Tumba 3.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Dragon Ball Z La Resurreccion de Freezer\Dragon Ball Z La Resurreccion de Freezer.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Hotel Transilvania 2\Hotel Transilvania 2.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Cuentos de Halloween\Cuentos de Halloween.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Escala En detroit\Escala En detroit.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\From The Dark\From The Dark.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Cartel Land\Cartel Land.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Boa Sorte\Boa Sorte.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Awaiting\Awaiting.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Armi Elaa!\Armi Elaa!.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Hidden Terror En Kingsville\Hidden Terror En Kingsville.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Transilvania, El Imperio Prohibido\Transilvania, El Imperio Prohibido.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Barbie & Her Sisters In The Great Puppy Adventure\Barbie & Her Sisters In The Great Puppy Adventure.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]C:\kodi\Peliculas\Amnesiac\Amnesiac.strm Agregados
18:08:40 T:6420 NOTICE: [Videoteca2KD - TVGUIA]40 MOVIE agregados./n
18:08:40 T:3080 NOTICE: VideoInfoScanner: Starting scan ..
18:08:40 T:3080 WARNING: No information found for item 'C:\kodi\Peliculas\13 Dies Doctubre\13 Dies Doctubre.strm', it won't be added to the library.
18:08:43 T:7376 NOTICE: Thread FileCache start, auto delete: false
18:08:44 T:3080 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:04
18:08:44 T:1236 NOTICE: Thread BackgroundLoader start, auto delete: false
18:08:49 T:2900 NOTICE: Previous line repeats 2 times.
18:08:49 T:2900 NOTICE: Thread LanguageInvoker start, auto delete: false
18:08:49 T:2900 NOTICE: -->Python Interpreter Initialized<--
18:08:49 T:2900 NOTICE: pelisalacarta.core.config PLATFORM_NAME=kodi-isengard
18:08:49 T:2900 NOTICE: pelisalacarta.core.config runtime path = C:\Users\Javier\AppData\Roaming\Kodi\addons\plugin.video.pelisalacarta
18:08:49 T:2900 NOTICE: pelisalacarta.core.config data path = C:\Users\Javier\AppData\Roaming\Kodi\userdata\addon_data\plugin.video.pelisalacarta\
18:08:49 T:2900 NOTICE: pelisalacarta.core.config temp path = C:\Users\Javier\AppData\Roaming\Kodi\cache\test
18:08:49 T:2900 NOTICE: send:
18:08:49 T:2900 NOTICE: 'GET /es/pelicula/0009001/ver-the-martian-online.html HTTP/1.1\r\nAccept-Language: es-ES,es;q=0.8\r\nAccept-Encoding: gzip,deflate,sdch\r\nHost:
www.yaske.cc\r\nAccept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8\r\nUser-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/37.0.2062.120 Safari/537.36\r\nConnection: close\r\nReferer:
http://www.yaske.cc/\r\n\r\n'
18:08:49 T:2900 NOTICE: reply:
18:08:49 T:2900 NOTICE: 'HTTP/1.1 200 OK\r\n'
18:08:49 T:2900 NOTICE: header:
18:08:49 T:2900 NOTICE: Last-Modified: Sun, 18 Oct 2015 18:04:04 GMT
18:08:49 T:2900 NOTICE: Content-Type: text/html
18:08:49 T:2900 NOTICE: Content-Length: 17416
18:08:49 T:2900 NOTICE: Content-Encoding: gzip
18:08:49 T:2900 NOTICE: Vary: Accept-Encoding
18:08:49 T:2900 NOTICE: Date: Sun, 18 Oct 2015 23:08:48 GMT
18:08:49 T:2900 NOTICE: Accept-Ranges: bytes
18:08:49 T:2900 NOTICE: Server: LiteSpeed
18:08:49 T:2900 NOTICE: Connection: close
18:08:52 T:7708 NOTICE: DVDPlayer: Opening: http%3A%2F%2Folo.gg%2Fs%2FcJinsNv1%3Fs%3Dhttp%253A%252F%252Fstreamin.to%252Fya0peus74hk9
18:08:52 T:7708 WARNING: CDVDMessageQueue(player):
ut MSGQ_NOT_INITIALIZED
18:08:52 T:7756 NOTICE: Thread DVDPlayer start, auto delete: false
18:08:52 T:7756 NOTICE: Creating InputStream
18:08:52 T:7756 ERROR: CDVDPlayer::OpenInputStream - error opening [http%3A%2F%2Folo.gg%2Fs%2FcJinsNv1%3Fs%3Dhttp%253A%252F%252Fstreamin.to%252Fya0peus74hk9]
18:08:52 T:7756 NOTICE: CDVDPlayer::OnExit()
18:08:52 T:7708 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.pelisalacarta/?channel=yaske&action=play_from_library&url=http%3A%2F%2Fwww.yaske.cc%2Fes%2Fpelicula%2F0009001%2Fver-the-martian-online.html]
18:08:52 T:6304 NOTICE: Thread BackgroundLoader start, auto delete: false
18:08:52 T:7708 NOTICE: CDVDPlayer::CloseFile()
18:08:52 T:7708 NOTICE: DVDPlayer: waiting for threads to exit
18:08:52 T:7708 NOTICE: DVDPlayer: finished waiting
18:09:54 T:7708 NOTICE: Storing total System Uptime
18:09:54 T:7708 NOTICE: Saving settings
18:09:54 T:7708 NOTICE: stop all
18:09:54 T:7708 NOTICE: stop player
18:09:54 T:7708 NOTICE: PVRManager - stopping
18:09:55 T:7708 NOTICE: ES: Stopping event server
18:09:55 T:7708 NOTICE: stopping upnp
18:09:56 T:8040 NOTICE: ES: UDP Event server stopped
18:09:56 T:7708 NOTICE: stop sap announcement listener
18:09:56 T:7708 NOTICE: clean cached files!
18:09:56 T:7708 NOTICE: unload skin
18:10:01 T:7708 ERROR: CPythonInvoker(0, C:\Users\Javier\AppData\Roaming\Kodi\addons\script.videoteca2kd\service.py): script didn't stop in 5 seconds - let's kill it
18:10:02 T:7708 NOTICE: stopped
18:10:02 T:7708 NOTICE: destroy
18:10:02 T:7708 NOTICE: closing down remote control service
18:10:03 T:7708 NOTICE: unload sections
18:10:03 T:7708 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:10:04 T:7708 NOTICE: destroy
18:10:04 T:7708 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
18:10:04 T:7708 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
18:10:04 T:7708 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
18:10:04 T:7708 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
18:10:04 T:7708 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
18:10:04 T:7708 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
18:10:04 T:7708 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
18:10:04 T:7708 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
18:10:04 T:7708 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
18:10:04 T:7708 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
18:10:04 T:7708 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
18:10:04 T:7708 NOTICE: closing down remote control service
18:10:04 T:7708 NOTICE: unload sections
18:10:04 T:7708 NOTICE: application stopped...
18:10:04 T:7708 ERROR: dllFreeLibrary - Invalid hModule specified
