2006-02-13, 22:16
2006-02-14, 18:29
if someone fixes it, it also needs to support the xml inheritance. in pmiii ntsc derives its dialogsubmenu.xml from the pal folder but the script looks for it in the ntsc folder.
2006-02-14, 18:51
odd mine works fine... can you give me an exact build date as i am using 2-11
2006-02-14, 20:31
i noticed some bugs with some other script on recent builds...
i've got a script running here on my xbmc but not on a xbmc of a friend...
2006-02-14, 22:37
ok so, if i have it working and you have it working but your buddy doesnt.... perhaps you should look for dis similarities between yours and his rather than ask for the script to be unbugged.
2006-02-15, 00:05
i've tried running that script on about 4-6 builds now... never worked, always get some error (cannot remember now) so ijust don't use it... all fixed! :nuts:
2006-02-15, 15:35
Quote: - 25-01-2006 added: <onclick> (replaces <execute>)
it's easy to fix
just find and replace in text editor
execute to onclick
2006-02-16, 16:28
hi,
anytime i try to run this script it says it can't find dialogsubmenu.xml in the pmiii skin, anyone have a similar problem or a solution?
thanks
thanks
2006-02-16, 18:22
(skilltronix @ feb. 16 2006,07:28 Wrote:hi,that is the error i have always had... oh well.
thanks
2006-02-16, 19:52
(asteron @ feb. 14 2006,11:29 Wrote:if someone fixes it, it also needs to support the xml inheritance. in pmiii ntsc derives its dialogsubmenu.xml from the pal folder but the script looks for it in the ntsc folder.it's because of this.
2006-02-17, 01:47
