Full Version: Youtube 4.4.6 crash XBMC on stream stop or end.
Its not just Youtube plugins like PBS also exhibit same behaviour
Go select a video in youtube or pbs and start playback then either press after a while stop or let the playback reach end of stream.
crashlogs with debug enabled on youtube and extra rmtp etc turned on.
These are only for youtube addon as I feel if the problem is fixed in one it will automatically be fixed for all addons.
XBMC (13.0-ALPHA11 Git:20131222-ebc2f99). Platform: x86 Linux 64-bit
Using Debug XBMC x64 build, compiled Dec 22 2013 by GCC 4.6.3 for x86 Linux 64-bit 3.2.52
Link edited out as not needed anymore
I have a 52MB crashlog with debug enabled for this but tbh uploading that to pastebin is impossible. Ive zipped it and uploaded it only at 16MB.
I have also noticed the youtube addon deps on addon.xml are in need of update but I suspect relevant code also required.
<requires>
    <import addon="xbmc.python" version="2.1.0" />
    <import addon="script.module.simplejson" version="2.0.10" />            << is outdated current at version="3.3.0"
    <import addon="script.common.plugin.cache" version="2.5.2" />
    <import addon="script.module.parsedom" version="2.5.1" />               << is outdated current at version="2.5.2">
    <import addon="script.module.simple.downloader" version="1.9.4" />
  </requires>
anyway even the deps depend on outdated versions main probem is XBMC will crash at stopping stream or end of stream.
Ok I think after https://github.com/xbmc/xbmc/pull/3891 this may have been fixed. Though the addon dependencies are still incorrect.
