2013-12-24, 17:41
I moved XBMC 12.2 to a new PC, pretty similar to the old one. Everything seems to have gone smoothly except the MCE remote (Logitech Harmony One) is not working properly.
It responds to the "normal" commands. By that I mean the default buttons on a typical MCE remote (CUSOR KEYS, ENTER, STOP, PLAY, etc.). However, none of the other commands I've programmed into the remote are functioning, for example TAB, HOME, END, etc.
I did my custom keys on the Harmony One. It's been working fine for the past year, and still works on the old system. I never created a custom keyboard.xml. I did a search for "keyboard.xml" on the old and new systems and the only ones that exist are the default ones and the one in XBMX\system\keymaps.
I copied the userdata folder from the old system to the new one, so nothing's been changed. I've compared the two installations and can't find anything that's different.
What might I have overlooked?
