Full Version: Different resolution for video playback
Hi! new here, but old user of xbmc since xbox 1
I have a computer connected to a CRT TV using RGB scart
The maximum flicker free resolution I can have is 768x288 PAL 50hz, and xbmc works great, very nice to use the gui without flickering
My problem is that I want xbmc to switch to 768x576 or 768x480 just when I play videos, to have high resolution, and just switch to 768x288 when I return to xbmc menu
Is possible?
The xbox 1 xbmc have some very good flickering control, that I can set very high to the GUI, and disable in videos... sadly I don't see nothing like this in the windows port.. true? or I miss some option?
any ideas people?
thanks!
I don't know if you can just do this on videos, and leave the gui different. However, something like that may be possible with setting up a different profile.
Thank you! already tried profiles, but It did not work, when I change resolution for one profile, all other profiles use same resolution
Thanks again
