Full Version: Help installing Tvheadend..Ubuntu 12.04
I have searched the web for guide on installing Tvheadend...I'm somewhat new to Linux but not hopeless!!
Anyhow, I have Ubuntu 12.04.3 LTS + XBMC + Tvheadend PVR running but having hell of a time installing Tvheadend backend..
Can not make sense of the below stepsHuh
Please provide step by step guide...
BTW.. it asked for curl which I installed....sudo apt-get install curl....
If you had previously added the launchpad PPA, please be sure to remove it (as it no longer exists)
sudo apt-add-repository -r http://ppa.launchpad.net/adamsutton/tvheadend
Before you can use the repositories you probably want to import the GPG signing key:
curl http://apt.tvheadend.org/repo.gpg.key | sudo apt-key add -
You will then need to add which ever repository you feel is most appropriate, for example if you want to be cautious and have a reliable system:
sudo apt-add-repository http://apt.tvheadend.org/stable
sudo apt-get update
Note: if you install more than one repository you will only ever get packages from the one holding the most recent version number, so the order of priority would be:
unstable > beta > stable
You can easily remove a repository though, so should you suddenly come over all crazy and want to live on the edge:
sudo apt-add-repository -r http://apt.tvheadend.org/stable
sudo apt-add-repository http://apt.tvheadend.org/unstable
sudo apt-get update
sudo apt-get update
sudo apt-get install tvheadend
then you can configure it from the web interface http://YourServerIPAddress:9981/extjs.html
