Full Version: TVHEadend plugin makes 12.3 crash on exit
i am using the TVHeadend plugin under Mac OS X 10.9.1(MBPr) and 10.8.5(mini) with Frodo 12.3.
Frodo in general works nicely and exits as expected (finally with 12.3). But as soon as i enable the TVHeadend plugin, and then try to exit XBMC, it hangs on 10.8.5 and does not react anymore and on 10.9.1. it crashes (OS X bug reporter starting).
I did the followin on the MBPr to make sure its the plugin:
1) XBMC plain install: Started and then closed via menu --> fine
2) Started XBMC -> activated live TV -> moans for the missing PVR plugin -> closed via menu --> fine
3) Started XBMC -> activated Mediaportal PVR plugin -> moans for the missing backend connectivity -> closed via menu --> fine
4) Started XBMC -> disabled Mediaportal Plugin -> activated TV Headend -> crash, right after activation
5) Started XBMC(TVHeadend active) -> closed via menu -> crash (http://pastebin.ca/2517848)
6) Started XBMC -> Started LiveTV -> Stopped LiveTV -> closed via menu --> crash (http://pastebin.com/AXcDTg46)
Anyone able to analyze this?
Thx & Cheers,
Tom
same issue here under osx
and did not occur using the most recent test build of 12.3 (20130904 i believe it was) before the final was release
crash only occurs when tvheadend plugin is enabled
Same here.
tested on:
XBMC 12.3 (32 bit) on MBP OSX 10.6.8 and XBMC 12.3 (64 bit) on MBA OSX 10.8.5.
I have to use 'Force Quit' to close XBMC on exit or when de-selecting the option for live tv 'enabled'.
... that's all I've tested so far.
Same here: XBMC 12.3 (64bit) on MacMini 10.6.8
I had to revert to 12.2 and the problem disappears.
Is there really no dev interested in that issue?
(2013-12-30, 16:36)tom1502 Wrote: [ -> ]Is there really no dev interested in that issue?
I think the problem is many of the devs (especially on the PVR side) don't use Macs.
any news on this?
Being affected by this bug as well, I opened a ticket in the bug tracker:
http://trac.xbmc.org/ticket/14881
check gotham alpha. we won't fix any frodo issues now that gotham is nearly out
I will once I have time. Last time I tried end of dec, it still was "a big mess" Wink
You can use the addon on mac os with gotham?
