Full Version: Frodo 12.3 AmLogic build request
Hello!
I think very hard get support for amlogic or get somebody to make AMLogic supported version....Sad
Can somebody make a 12.3 AmLogic supported build and share with us a download link?
Without amlogic support i can see all movie as pictures Sad
For 4 days forum reading i have one 12.2, and a 13.0 alfa Amlogic supported xbmc, not too much...
ps: Somebody dont know the 13.0 alfa have currently home launcher function?
thank you
what do you mean all movie as pictures? As Amlogic is very common and there are plenty of thread and support for it if you use google search for amlogic xbmc
all movies as pictures = movie frame rate is too low
Buddy, im after 1 week google search here. There is no official amlogic supported version, just with some developer compiled versions.
Yeah very common, just nobody support currently here..
Because this is hw accelration, for this need one developer modify the source code, after compile a special version.
(2013-12-29, 10:36)hondas3000 Wrote: [ -> ]what do you mean all movie as pictures? As Amlogic is very common and there are plenty of thread and support for it if you use google search for amlogic xbmc
I want try out frodo final 12.3 but with so much support, there is no way...
I don't know what box did you use but as for now download this version and it should play all your movie smooth. http://mediafire.com/?21qgbmxtldwxoet .
What a player have you?
I have a Overmax Homebox chipset: AMLogic MESON-M1 8726M 1 core cpu with 1 core Mali 400
Other name of this set Goclever 500 or the compatible boxes are Pivos XIOS DS
One try with your linked XBMC.
(2013-12-29, 19:58)hondas3000 Wrote: [ -> ]I don't know what box did you use but as for now download this version and it should play all your movie smooth. http://mediafire.com/?21qgbmxtldwxoet .
