Full Version: Clicking Noise
I am using external player to play iso and bluray rips inside xbmc. When I click the movie to play I am hearing all the time clicking noises. I have found that this is a known issue and you can click to disable the gui clicks inside xbmc.
Is there another work around for this since I do not want to disable the gui clicks??
Which version of xbmc? I think this issue has been resolved in the 12.3. You can also try the latest nightly build.
(2013-12-27, 15:29)baijuxavior Wrote: [ -> ]Which version of xbmc? I think this issue has been resolved in the 12.3. You can also try the latest nightly build.
I have tried 12.3 and it is still there. Which version resolves the issue?
Try the Gotham nightly builds.
