2013-12-28, 01:36
Hello,
I'm trying to use MPC-HC as an external player, and I'm having issues with playing one episode after another. Actually, I'm able to play videos continuously using the "Play from here" option in the context menu, the real problem is STOPPING them.
With the default XBMC player, if I use "Play from here" it will allow me to stop the chain of videos by pressing the Stop button in the interface. With MPC-HC, the Stop button just stops the video without actually returning me to the XBMC menus. The only way I can see to exit MPC-HC is right clicking and pressing Exit, or closing the window. Both of these exit methods return me to the XBMC menus for a second, and then it loads the next video, so the only way to stop is to reach the end of the video list, or exit XBMC.
Is there any way to change this behavior?
Thanks in advance.
Thanks in advance.
