As a heads-up recently my python addon stopped playback on some videos on this error
20:17:28 T:4728 ERROR: EXCEPTION: Failed to convert to input type to either a std:
tring or a std::vector<(XBMCAddon::xbmcgui::InfoLabelStringOrTuple)>
and I narrowed it down to a None being passed as part of an Infolabel
{'Studio': None, 'Title': u'foobar'}
Setting Studio to '' fixes it so None types likely aren't allowed.
Martin
Thanks. This is due to a recent change I made to fix some other things. I'll fix this today.
Thanks jm for getting my attention.
Great, I got the nightly, put the code back to {'Studio': None, 'Title': u'foobar'} and it works.
Thanks a lot!
Martin
I just noticed though that it might be more than the None issue. I tried the YouTube pluging this morning and got a similar error to mine
11:37:38 T:8124 ERROR: EXCEPTION: Failed to convert to input type to either a std::string or a std::vector<(XBMCAddon::xbmcgui::InfoLabelStringOrTuple)>
11:37:38 T:8124 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: Failed to convert to input type to either a std::string or a std::vector<(XBMCAddon::xbmcgui::InfoLabelStringOrTuple)>
File "C:\Users\Martin\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py", line 122, in <module>
navigation.listMenu(params)
File "C:\Users\Martin\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubeNavigation.py", line 108, in listMenu
return self.list(params)
File "C:\Users\Martin\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubeNavigation.py", line 192, in list
self.parseVideoList(params, results)
File "C:\Users\Martin\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubeNavigation.py", line 487, in parseVideoList
self.addVideoListItem(params, result_params, listSize)
File "C:\Users\Martin\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubeNavigation.py", line 445, in addVideoListItem
listitem.setInfo(type='Video', infoLabels=item_params)
TypeError: Failed to convert to input type to either a std::string or a std::vector<(XBMCAddon::xbmcgui::InfoLabelStringOrTuple)>
I rolled back prior to the change and the YouTube plugin works.
Martin
The problem is now is InfoLabel don't like the python decimal type
Martin
(2013-12-30, 21:09)emveepee Wrote: [ -> ]The problem is now is InfoLabel don't like the python decimal type
Martin
Confirm this. If used str or unicode instead decimals all is fine.
Does this include the commit above? That should have resolved it.
Removed the rating infolabel and works. Decimal problem maybe.
But I can't get cast/castandrole listitem to work. I've tried many ways, list,dictionary.. 20131229
Quote:TypeError: Failed to convert to input type to either a std:tring or a std::vector<(XBMCAddon::xbmcgui::InfoLabelStringOrTuple)>
I reproduced the problem with the YouTube plugin. Thanks, I'll fix it.
fightnight, this now works for the Apple Movie Trailer plugin which calls setInfo using 'cast'. Can you post a test case that reproduces the problem? If so I'm sure I can fix it or at least let you know what the problem is.
Jim
The commit works for my original None issue be no decimals in the YouTube plugin
Edit nevermind I see you can duplicate it.
Martin
Just tested "Apple iTunes Trailers". It has cast but on plot.
Empty cast.
http://xbmclogs.com/show.php?id=103721
