2013-12-28, 17:55
Pages: 1 2
2013-12-28, 17:55
2013-12-28, 18:15
in xbmc settings/network
2013-12-28, 18:28
(2013-12-28, 18:15)neurosis13 Wrote: [ -> ]in xbmc settings/network
In xbmc settings/network not have the required data.
2013-12-28, 19:02
You only need the IP address of your Windows 8 system, and to set a parameter in XBMC itself.
Bring up XBMC
Goto System->Services->Webserver
Set the parameter 'Allow control of XBMC via HTTP'
Goto System->System info->Summary
Make a note of the IP address displayed (e.g. 192.168.10.9)
Enter this address into the remote-app on your Nokia Lumia 520 et voila!
Please note, if you shutdown or power-off your Windows system, or your router this IP address may change and you will have to go through this procedure again.
Bring up XBMC
2013-12-28, 22:14
(2013-12-28, 19:02)elusien Wrote: [ -> ]You only need the IP address of your Windows 8 system, and to set a parameter in XBMC itself.
Bring up XBMC
I've tried, but the problem is not solved.
2013-12-28, 23:08
Do you have something running on port 80 already? Try another port.
2013-12-29, 13:06
(2013-12-28, 23:08)nickr Wrote: [ -> ]Do you have something running on port 80 already? Try another port.
Port 8080 works, but I can't remote.
Search my user name and password. Is this applies to the username and password for XBMC? Asks me and MAC address. Problem and with XBMC Server address. Whatever I enter, does not work.
2013-12-29, 22:33
Username and password are set on the same page.
2013-12-30, 01:11
(2013-12-29, 22:33)nickr Wrote: [ -> ]Username and password are set on the same page.
Is this applies to the username and password for XBMC? Where is MAC address? What is XBMC Server address?
I need complete tutorial.
2013-12-30, 01:26
The username and password you set in xbmc are the ones you use in the remote app. You don't need to use the Mac address, it is only for WOL. the xbmc server address is the IP address of your xbmc machine, or it's hostname if dns works on your LAN.
2013-12-30, 13:03
(2013-12-30, 01:26)nickr Wrote: [ -> ]The username and password you set in xbmc are the ones you use in the remote app. You don't need to use the Mac address, it is only for WOL. the xbmc server address is the IP address of your xbmc machine, or it's hostname if dns works on your LAN.
Where search IP address of my xbmc machine. I am doing this for the first time, so I do not understand.
Sorry for this questions from me. Sorry for my English.
2013-12-30, 13:06
A simple google search will tell you how to find your IP address
http://www.wikihow.com/Find-the-IP-Address-of-Your-PC
2013-12-30, 16:31
(2013-12-30, 13:06)prawnee Wrote: [ -> ]A simple google search will tell you how to find your IP address
Is it IP address of ISP? If yes, it not work for me.
Is it username and password of this Forum?
Whatever I do, this is not working.
2013-12-30, 16:50
No it's not the username and password for the forum. Username and password is set within XBMC if you haven't set one leave these fields blank, also take a look at this
https://code.google.com/p/android-xbmcre..._and_later
2013-12-30, 17:18
Its not your external IP address either (ISP), its the local address of the machine running XBMC. On windows, press the Win key (with the flag on) and r at the same time. Type cmd and press enter. In the black box, type ipconfig and press enter. It'll tell you your local IP address next to IP Address. Thats the address to put into your remote.
Pretty sure that's correct although its been a while lol
Pages: 1 2
