Full Version: EMM 1.3.0.18 scraping issues
Im using EMM 1.3.0.18 to scrap movies and getting a bunch of errors in terms of posters, fanart. I also recall an option to copy the plot outline if the plot is empty and cant find that option either.
I get option to select images but they dont save from the program. Also, fanart.tv doesnt work for me either....
here is my error logs
================= <Assembly Versions> =================
Platform: x86
Ember Application (Revision: 1.3.0.18)
Ember API (Revision: 1.3.0.17)
Ember Extras Scraper (Revision: 1.3.0.12)
Ember Native Movie Scrapers (Revision: 1.3.0.18)
Ember TMDB Movie Scrapers (Revision: 1.3.0.18)
Ember XML Scraper (Revision: 1.3.0.5)
Renamer (Revision: 1.3.0.12)
Frame Extractor (Revision: 1.3.0.12)
Media File Manager (Revision: 1.3.0.5)
Movie List Exporter (Revision: 1.3.0.12)
NMT Jukebox Builder (Revision: 1.3.0.13)
Notifications (Revision: 1.3.0.14)
Offline Media Manager (Revision: 1.3.0.15)
XBMC Controller (Revision: 1.3.0.5)
Boxee Compatibility (Revision: 1.3.0.12)
MediaBrowser Compatibility (Revision: 1.3.0.12)
YAMJ Compatibility (Revision: 1.3.0.12)
Genres Editor (Revision: 1.3.0.12)
Media Sources Editor (Revision: 1.3.0.12)
Audio & Video Codec Mapping (Revision: 1.3.0.12)
Trakt Settings (Revision: 1.3.0.12)
Ember Native TV Scrapers (Revision: 1.3.0.18)
Title: Error
Message: Object reference not set to an instance of an object.
StackTrace: at Ember_Media_Manager.dlgEditMovie.btnSetPosterDL_Click(Object sender, EventArgs e)
Date/Time: 12/28/2013 11:45:57 AM
Title: Error
Message: HTTP Error
StackTrace:
Date/Time: 12/28/2013 11:45:58 AM
Title: Error
StackTrace: at EmberScraperModule.dlgImgSelect.IsTMDBURL(String sURL)
at EmberScraperModule.dlgImgSelect.ProcessPics(List`1 posters)
Date/Time: 12/28/2013 11:46:31 AM
Title: Error
Message: HTTP Error
StackTrace:
Date/Time: 12/28/2013 12:15:24 PM
Title: Error
Message: Access to the path 'F:\Program Files\Ember_1.3.0.18\AdvancedSettings.xml' is denied.
StackTrace: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at System.Xml.XmlTextWriter..ctor(String filename, Encoding encoding)
at System.Xml.XmlDocument.Save(String filename)
at EmberAPI.AdvancedSettings.Save()
Date/Time: 12/28/2013 12:16:14 PM
Title: Error
Message: Invalid API key - You must be granted a valid key
StackTrace: 7
Date/Time: 12/28/2013 12:27:38 PM
Title: Error
Message: HTTP Error
StackTrace:
Date/Time: 12/28/2013 12:28:11 PM
Title: Error
Message: HTTP Error
StackTrace:
Date/Time: 12/28/2013 12:28:12 PM
Title: Error
Date/Time: 12/28/2013 12:28:44 PM
Is F:\Program Files your system disc?
If so move the Ember folder somewhere else outside "Program files"
It fixed it, thanks!
Ah weird; what's the reason it doesn't work in Program Files?
Win 7 and higher has restrictions for applications to write there, it's possible to change but better to put it somewhere else
(2014-01-03, 22:07)T-bird_se Wrote: [ -> ]Win 7 and higher has restrictions for applications to write there, it's possible to change but better to put it somewhere else
I have Ember installed in c:\program files which is also my system disk and the program works fine. I guess its because I have UAC disabled.
