2014-01-01, 04:33
I have been running XBMCbuntu 12.0 on my Zotac Mags for a year now without issues. So I went to upgrade to 12.3 and I found a problem. It looks like when you pause video playback for longer than 10 seconds on resume there is no audio. I also notice there are no sounds when in menu's after that. What I did find it that going into alsamixer and muting then unmuting S/PDIF 1 immediately solves the problem in real time until the next time you pause all other controls do not. You can also stop the video them reply and the audio is back as well. my brain is also telling me that when there is no activity for the same period in the gui the audio disspears as well
System is a Zotac Mag ION chipset attached to TV via HDMI. Audio is setup to 2.0 (2.1 tried) output and no other options enabled. I tried every HDMI and passthough device with no luck same issue.
So I tried a clean install of 12.2 XBMCbuntu and have the same issue. Never had this issue with the 12.0 install's
Anyone have any ideas? If you need logs plese point me to how to get them
IBJ
IBJ
