Full Version: transparency problem?
hi all, i just installed xbmc 12.3/Aeon Nox on my laptop and i'm having problems with the backgrounds being transparent. this means that the text is running on top of other background text and is unreadable. ive never had this problem on my HTPC. also having problems displaying tv extra fanart. could it be that i'm using same media files from my HTP which is frodo 12.2? i'm confused. any help is truly appreciated.
windows 7, sp1 64bit
AMD Turion II 540 Dual Core 2.4GHz
6GB RAM
Radeon HD4200
(if i forgot any info let me know)
FIXED. just had to restart the application. very strange.
Were you able to find a fix for this?
