2014-01-01, 08:52
Hi guys
First of all, I've been using XBMC for many many years now, and this is my first post in the forum, so hi!
I recently rebuilt my computer, as in re-installed windows 7, and I'm now having some strange issues with my library.
This has happened twice. The first time I uninstalled XBMC and removed all the preferences, but the result is the same.
The movies will download all the correct information, but the last 20 or so (maybe more) all show up as being the same movie La Chasse de Papillon.
Very different from the actual movies.
If it was one, I would consider it being a naming issue, but this many, it has to be something else.
I can't tell if it's the same movies each time, I didn't check which ones they were the first time.
Any help would be appreciated.
