2014-01-01, 13:15
Pages: 1 2
2014-01-03, 01:40
I actually was looking for this in the past
2014-11-21, 07:29
same
2014-11-21, 08:07
Not a screensaver, but you can download a fireplace video from youtube, put it in a playlist, then set it to repeat.
It would be nice to be able to activate a video as a screensaver.
http://youtu.be/IExpnvKDnnU
2014-12-06, 01:18
Would it be hard to code? I wouldnt think so just ask xbmc to pull up video archive instead of pictures... or is it much more complex?
2014-12-08, 19:27
Hi All,
I have had a bit of a play and now have a screensaver that will play a video for you. It's currently classed as "beta", but is available to try by downloading the zip file from:
https://robwebset.googlecode.com/svn/rel...-0.0.1.zip
One bit still to finish is actually the icon (There is currently no text on it - should have the name: VideoScreensaver) will complete that soon.
So you have the option to either have it play your own video file, or a default Aquarium/Fireplace one - note that it will need to download the default ones when you select them, but it will be cached locally for future playing.
If people like this I will start enhancing it and putting in more stuff. I will also try and push it to the official repo.
Please give it a go and let me know how you get on.
Rob
Rob
2014-12-08, 20:39
nice i'm willing to give this a try,
just need to find a Aquarium or Wood Burning Video i can use
2014-12-08, 20:45
(2014-12-08, 20:39)TRaSH Wrote: [ -> ]nice i'm willing to give this a try,
There is a setting built in that will do it for you!
Rob
2014-12-08, 23:40
2014-12-09, 10:04
Hi All,
Another update, this includes the following additions:
https://robwebset.googlecode.com/svn-his...-0.0.2.zip
Please let me know how you get on
Rob
v0.0.2
- Add option for time to be shown in the corner
- Make video loop if screensaver still active
- Add option to start video at a random place
- Add text to addon icon
Rob
2014-12-11, 06:58
(2014-12-09, 10:04)rob_webset Wrote: [ -> ]Hi All,
Code:v0.0.2
Rob
Hey, just a question if I pause a video will the screen saver activate and replace the currently playing video with lets say a fireplace?
2014-12-11, 08:46
(2014-12-11, 06:58)DoJo_Mast3r Wrote: [ -> ]Hey, just a question if I pause a video will the screen saver activate and replace the currently playing video with lets say a fireplace?
No, if a video is paused, my testing has shown that is screen will just dim.
Rob
2014-12-11, 09:14
Thanks!, Using it on 2 raspberry pies currently... Just asking the community im a little worried running a video non stop on such a low powered computered. Will it shorten the life of the pi?
2017-01-05, 15:41
Does anyone know if this will still work in Jarvis?
2017-01-05, 21:14
There is video screen saver that works in Jarvis, but videos are not available... they were downloadable from the addon, but not anymore.. If anyone would have those....
Pages: 1 2
