Full Version: Streaming some channels bug? (with debug log)
As you can see in the log there are some issues with a few channels when you try to stream to the XBMC.
This is just an example of one of those channels.
Should I open something on the bugtracker?
02:25:12 T:5108 INFO: AddOnLog: VU+ / Enigma2 Client: Vu::GetHttpXML Got result. Length: 190
02:25:12 T:5108 DEBUG: CFileCache::Open - opening <1:0:1:138A:30:36:CE40000:0:0:0> using cache
02:25:12 T:5108 DEBUG: CurlFile::Open(0B8B7008) http://xxx.xxx.xxx.xxx:8001/1:0:1:138A:3...0000:0:0:0
02:25:12 T:5164 DEBUG: Caching image 'http://xxx.xxx.xxx.xxx:80/picon/1_0_1_13AB_27_36_CE40000_0_0_0.png' to 'f/f1ceafbb.png':
02:25:12 T:5164 DEBUG: cached image 'special://masterprofile/Thumbnails/f/f1ceafbb.png' size 220x132
02:25:12 T:148 DEBUG: Caching image 'http://xxx.xxx.xxx.xxx:80/picon/1_0_1_73_65_53_CE40000_0_0_0.png' to '8/88428f7c.png':
02:25:12 T:148 DEBUG: cached image 'special://masterprofile/Thumbnails/8/88428f7c.png' size 220x132
02:25:12 T:2880 DEBUG: Caching image 'http://xxx.xxx.xxx.xxx:80/picon/1_0_1_57E_68_53_CE40000_0_0_0.png' to '0/0fa5f89d.png':
02:25:12 T:2880 DEBUG: cached image 'special://masterprofile/Thumbnails/0/0fa5f89d.png' size 220x132
02:25:12 T:7332 DEBUG: Caching image 'http://xxx.xxx.xxx.xxx:80/picon/1_0_1_138A_30_36_CE40000_0_0_0.png' to '4/437775ae.png':
02:25:12 T:7332 DEBUG: cached image 'special://masterprofile/Thumbnails/4/437775ae.png' size 220x132
02:25:14 T:5108 DEBUG: CDVDInputStreamPVRManager::Open - stream opened: http://xxx.xxx.xxx.xxx:8001/1:0:1:138A:3...0000:0:0:0
02:25:14 T:5108 NOTICE: Creating Demuxer
02:25:14 T:8444 NOTICE: Thread CFileCache start, auto delete: false
02:25:14 T:5108 DEBUG: CDVDDemuxFFmpeg::Open - probing detected format [mpegts]
02:25:14 T:5108 DEBUG: CDVDDemuxFFmpeg::Open - avformat_find_stream_info starting
02:25:14 T:5108 ERROR: ffmpeg[13F4]: [mp2] Header missing
02:25:14 T:5108 ERROR: ffmpeg[13F4]: [NULL] non-existing PPS referenced
02:25:14 T:5108 ERROR: ffmpeg[13F4]: [h264] non-existing PPS 0 referenced
02:25:14 T:5108 ERROR: ffmpeg[13F4]: [h264] decode_slice_header error
02:25:14 T:5108 ERROR: ffmpeg[13F4]: [h264] no frame!
02:25:14 T:5108 ERROR: ffmpeg[13F4]: [h264] non-existing PPS referenced
02:25:15 T:5108 ERROR: ffmpeg[13F4]: [h264] non-existing PPS referenced
02:25:15 T:5108 ERROR: ffmpeg[13F4]: [h264] non-existing PPS 0 referenced
02:25:15 T:5108 ERROR: ffmpeg[13F4]: [h264] decode_slice_header error
02:25:15 T:5108 ERROR: ffmpeg[13F4]: [h264] no frame!
02:25:15 T:5108 DEBUG: ffmpeg[13F4]: [h264] Current profile doesn't provide more RBSP data in PPS, skipping
02:25:15 T:5108 ERROR: ffmpeg[13F4]: [h264] Missing reference picture
02:25:15 T:5108 DEBUG: ffmpeg[13F4]: [h264] Increasing reorder buffer to 1
02:25:15 T:5108 DEBUG: ffmpeg[13F4]: [h264] Increasing reorder buffer to 2
02:25:16 T:5108 DEBUG: ffmpeg[13F4]: [h264] Current profile doesn't provide more RBSP data in PPS, skipping
02:25:19 T:5108 DEBUG: Previous line repeats 2 times.
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] max_analyze_duration 5000000 reached at 5016000
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 0 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] Could not find codec parameters (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16)
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 1 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] Could not find codec parameters (Video: h264 ([27][0][0][0] / 0x001B))
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 2 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 3 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 4 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 5 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 6 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 7 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 8 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 9 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 10 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 11 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 13 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 14 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 15 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 16 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 17 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 18 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 19 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 20 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 21 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 22 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 23 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 24 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 25 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 26 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 28 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 29 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 30 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 31 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 32 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 33 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 34 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 35 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 36 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 37 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 38 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 39 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 40 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 41 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 42 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 43 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 44 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 45 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 46 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 47 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 48 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 49 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 50 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 51 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 52 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 53 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 54 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] Could not find codec parameters (Unknown: none ([5][0][0][0] / 0x0005))
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] decoding for stream 55 failed
02:25:19 T:5108 DEBUG: ffmpeg[13F4]: [mpegts] Estimating duration from bitrate, this may be inaccurate
02:25:19 T:5108 DEBUG: CDVDDemuxFFmpeg::Open - av_find_stream_info finished
02:25:19 T:5108 INFO: ffmpeg[13F4]: Input #0, mpegts, from 'pvr://channels/tv/All TV channels/60.pvr':
02:25:19 T:5108 INFO: ffmpeg[13F4]: Duration: N/A, start: 40093.554156, bitrate: 192 kb/s
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 4
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:54[0x21]: Unknown: none ([5][0][0][0] / 0x0005)
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:55[0x22]: Unknown: none ([5][0][0][0] / 0x0005)
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 231
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:23[0x1901](por): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:24[0x1900]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 232
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:26[0x1902]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:25[0x1903](por): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 233
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:12[0x1905](eng): Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16, 192 kb/s
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:27[0x1904]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuvj420p, 720x576 [SAR 64:45 DAR 16:9], 32.74 fps, 50 tbr, 90k tbn, 50 tbc
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 234
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:29[0x1907](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:28[0x1906]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 235
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:31[0x1909](por): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:30[0x1908]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 236
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:32[0x1911](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:33[0x1910]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 237
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:35[0x1912]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:34[0x1913](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 238
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:36[0x1915](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:37[0x1914]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 239
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:39[0x1917](spa): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:38[0x1916]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 240
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:41[0x1918]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:40[0x1919](por): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 241
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:42[0x1924](spa): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:43[0x1923]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 242
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:44[0x1926](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:45[0x1925]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 243
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:46[0x1927]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:47[0x1928](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 244
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:49[0x1933]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:48[0x1934](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 245
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:51[0x1936](por): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:50[0x1935]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:53[0x1956](spa): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:52[0x1955](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 246
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:3[0x1938](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:4[0x1937]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 247
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:5[0x1944](por): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:6[0x1943]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:7[0x1957](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 248
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:8[0x1945]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:9[0x1946](spa): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 249
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:10[0x1947]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:11[0x1948](por): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 250
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:0[0x1954](por): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:1[0x1953]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn, 180k tbc
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:2[0x1958](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 501
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:13[0x1d07](por): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:14[0x1d06]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 504
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:15[0x1d02]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:16[0x1d03](fra): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 506
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:17[0x1d0e]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:18[0x1d0f](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 513
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:19[0x1d17](por): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:20[0x1d16]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 514
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:21[0x1d19](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16
02:25:19 T:5108 INFO: ffmpeg[13F4]: Stream #0:22[0x1d18]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5000
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5001
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5002
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5003
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5004
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5005
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5006
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5007
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5008
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5009
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5010
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5011
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5012
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5013
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5014
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5015
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5016
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5017
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5018
02:25:19 T:5108 INFO: ffmpeg[13F4]: Program 5019
02:25:19 T:5108 DEBUG: CDVDPlayer::SetCaching - caching state 2
02:25:19 T:5108 WARNING: CDVDMessageQueue(audio):Tongueut MSGQ_NOT_INITIALIZED
02:25:19 T:5108 WARNING: CDVDMessageQueue(video):Tongueut MSGQ_NOT_INITIALIZED
It looks like the addon is feeding XBMC the full transport stream instead of just the program you want to watch. Can you post a full debug log to xbmclogs.com including where you play a working channel and one that doesn't?
Hello negge, here goes:
Working log - http://xbmclogs.com/show.php?id=104471
Non-working log - http://xbmclogs.com/show.php?id=104506
I'm sorry, I have no idea about this one.
