Full Version: Can't access dialogue box
I have Xbmc Frodo 12.3 installed on my IMac version 10.9.1. Problem I have is that when Xbmc loads; it will eventually ask me, via a dialogue box if I want to allow Xbmc to accept incoming connections. It gives two choices; Deny or allow. Problem I have is that my mouse pointer is unable to enter the box to make the choice. I can maneuver it any where on the screen; but not into the box. Than I have the problem of the box remaining dead center of the screen and I can't get rid of it. I have reinstalled Xbmc and rebooted, with negative results!
Any suggestions
Try using Expose to show the desktop or another app, so the mouse shows up again, and then flip back to XBMC using command+tab.
Sorry I didn't get back to you sooner. Tried what you suggested and it eventually worked.
