2014-01-03, 16:42
Hi fellow xbmc users and xbmc developers, first of many many thanks for a great media center!
I have been having problems all day getting new a new XBMC build working. I have had a working XBMC build for a month since I build a new HTPC. As the title says i get the following error in /var/log/syslog:
I have tried to search for the specific error both on forums, google and even in the xbmc github code base but could not find defines for such error messages.
Specifications and logs
Hardware:
Motherboard: ASUS C8HM70-I/HDMI
RAM: Corsair 4GB DDR3 PC3-10600 1333MHz SO-DIMM (9-9-9-24) (CMSO4GX3M1A1333C9).
Linux:
Distro: Debian 7.3
Arch: x86_64
Kernel: Linux 3.2.0-4-amd64 #1 SMP Debian 3.2.51-1
XBMC:
Release: 12.3 | Also tried building source from github
Build: Compiling with commands: sudo ./bootstrap ; sudo ./configure --enable-vdpau --enable-vaapi --enable-crystalhd --enable-libbluray --enable-nfs --enable-airplay ; sudo make ; sudo make install
XBMC is built successfully and placed what I presume is correct:
Then XBMC is started through init.d script:
[/code]
XBMC crash log:
I do now quite understand if either libcec nor alsa would be the problem since it was working before i begin building the new version and if im not completely deranged or got struck by Alzheimer i have done nothing with the htpc more than rebooted it in hopes that some unloaded module was missing. But if this tells someone anything please do tell me and point to what i have done wrong
Output of lsmod:
Output from lspci:
If i have left out anything just tell me what output you need and ill update this post with it!
Jan 3 15:15:51 chronos kernel: [ 8376.104833] xbmc.bin[16963]: segfault at 0 ip (null) sp 00007fff68e81c78 error 14 in xbmc.bin[400000+1116000]
Hardware:
Linux:
Distro: Debian 7.3
Arch: x86_64
XBMC:
chronos@chronos:/usr/src/xbmc-12.3-Frodo$ sudo make install
[sudo] password for chronos:
Copying XBMC binary to /usr/local/lib/xbmc/
You can run XBMC with the command 'xbmc'
Copying support and legal files...
Done!
Copying system files to /usr/local/share/xbmc
#! /bin/sh
### BEGIN INIT INFO
# Provides: xbmc
# Required-Start: $all
# Required-Stop: $all
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: starts instance of XBMC
# Description: starts instance of XBMC using start-stop-daemon and xinit
### END INIT INFO
############### EDIT ME ##################
# path to xinit exec
DAEMON=/usr/bin/xinit
# startup args
DAEMON_OPTS=" /usr/local/bin/xbmc --standalone -- :0"
# script name
NAME=xbmc
# app name
DESC=XBMC
# user
RUN_AS=root
# Path of the PID file
PID_FILE=/var/run/xbmc.pid
############### END EDIT ME ##################
test -x $DAEMON || exit 0
set -e
case "$1" in
start)
echo "Starting $DESC"
start-stop-daemon --start -c $RUN_AS --background --pidfile $PID_FILE --make-pidfile --exec $DAEMON -- $DAEMON_OPTS
stop)
echo "Stopping $DESC"
start-stop-daemon --stop --pidfile $PID_FILE
restart|force-reload)
echo "Restarting $DESC"
sleep 5
N=/etc/init.d/$NAME
echo "Usage: $N {start|stop|restart|force-reload}" >&2
exit 1
esac
exit 0
[/code]
XBMC crash log:
############### STACK TRACE #################
=====> Core file: /core (2014-01-03 15:15:51.201482957 +0100)
[New LWP 16963]
[New LWP 16977]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/local/lib/xbmc/xbmc.bin --standalone'.
Program terminated with signal 11, Segmentation fault.
#0 0x0000000000000000 in ?? ()
Thread 2 (Thread 0x7ff315281700 (LWP 16977)):
#0 0x00007ff31d69ae33 in poll () from /lib/x86_64-linux-gnu/libc.so.6
#1 0x00007ff31f5a6a7f in ?? () from /usr/lib/x86_64-linux-gnu/libasound.so.2
#2 0x0000000000bd730a in CAESinkALSA::AddPackets (this=0x2b50600, data=0x2b8a880 "", frames=2048, hasAudio=<optimized out>) at Sinks/AESinkALSA.cpp:527
#3 0x0000000000bcc096 in CSoftAE::RunOutputStage (this=0x2aa4da0, hasAudio=false) at Engines/SoftAE/SoftAE.cpp:1236
#4 0x0000000000bcf626 in CSoftAE::Run (this=0x2aa4da0) at Engines/SoftAE/SoftAE.cpp:1061
#5 0x000000000115e7a0 in CThread::Action (this=0x2bbab50) at Thread.cpp:218
#6 0x000000000115ea52 in CThread::staticThread (data=0x2bbab50) at Thread.cpp:128
#7 0x00007ff32259bb50 in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#8 0x00007ff31d6a5a7d in clone () from /lib/x86_64-linux-gnu/libc.so.6
#9 0x0000000000000000 in ?? ()
Thread 1 (Thread 0x7ff325f767a0 (LWP 16963)):
#1 0x0000000000e90dc3 in PERIPHERALS::CPeripheralBusCEC::PerformDeviceScan (this=0x2baf2b0, results=...) at virtual/PeripheralBusCEC.cpp:85
#2 0x0000000000e8ddca in PERIPHERALS::CPeripheralBus::ScanForDevices (this=0x2baf2b0) at PeripheralBus.cpp:125
#3 0x0000000000e8c69d in PERIPHERALS::CPeripheralBus::Initialise (this=0x2baf2b0) at PeripheralBus.cpp:226
#4 0x0000000000ea9401 in PERIPHERALS::CPeripherals::Initialise (this=0x17cb720) at Peripherals.cpp:94
#5 0x0000000000f7e2ef in CApplication::Create (this=0x2a55190) at Application.cpp:762
#6 0x0000000001011c54 in XBMC_Run (renderGUI=true) at xbmc.cpp:44
#7 0x00000000007c86db in main (argc=2, argv=0x7fff68e87678) at main.cpp:77
############# END STACK TRACE ###############
################# LOG FILE ##################
15:15:50 T:140682290751392 NOTICE: -----------------------------------------------------------------------
15:15:50 T:140682290751392 NOTICE: Starting XBMC (12.3 Git:Unknown), Platform: Linux (Debian GNU/Linux 7.3 (wheezy), 3.2.0-4-amd64 x86_64). Built on Jan 3 2014
15:15:50 T:140682290751392 NOTICE: special://xbmc/ is mapped to: /usr/local/share/xbmc
15:15:50 T:140682290751392 NOTICE: special://xbmcbin/ is mapped to: /usr/local/lib/xbmc
15:15:50 T:140682290751392 NOTICE: special://masterprofile/ is mapped to: /root/.xbmc/userdata
15:15:50 T:140682290751392 NOTICE: special://home/ is mapped to: /root/.xbmc
15:15:50 T:140682290751392 NOTICE: special://temp/ is mapped to: /root/.xbmc/temp
15:15:50 T:140682290751392 NOTICE: The executable running is: /usr/local/lib/xbmc/xbmc.bin
15:15:50 T:140682290751392 NOTICE: Local hostname: chronos
15:15:50 T:140682290751392 NOTICE: Log File is located: /root/.xbmc/temp/xbmc.log
15:15:50 T:140682290751392 DEBUG: ConsoleKit.Manager: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.ConsoleKit was not provided by any .service files
15:15:50 T:140682290751392 DEBUG: UPower: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
15:15:50 T:140682290751392 DEBUG: DeviceKit.Power: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.DeviceKit.Disks was not provided by any .service files
15:15:50 T:140682290751392 DEBUG: Systemd error: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.login1 was not provided by any .service files
15:15:50 T:140682290751392 DEBUG: Previous line repeats 1 times.
15:15:50 T:140682290751392 DEBUG: CAESinkALSA - HDMI device "hdmi:CARD=PCH,DEV=0" may be unconnected (no ELD data)
15:15:50 T:140682290751392 ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
15:15:50 T:140682290751392 NOTICE: Found 1 Lists of Devices
15:15:50 T:140682290751392 NOTICE: Enumerated ALSA devices:
15:15:50 T:140682290751392 NOTICE: Device 1
15:15:50 T:140682290751392 NOTICE: m_deviceName : @
15:15:50 T:140682290751392 NOTICE: m_displayName : Default (HDA Intel PCH ALC887-VD Analog)
15:15:50 T:140682290751392 NOTICE: m_displayNameExtra:
15:15:50 T:140682290751392 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:15:50 T:140682290751392 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE
15:15:50 T:140682290751392 NOTICE: m_sampleRates : 44100,48000,96000,192000
15:15:50 T:140682290751392 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
15:15:50 T:140682290751392 NOTICE: Device 2
15:15:50 T:140682290751392 NOTICE: m_deviceName : @:CARD=PCH,DEV=0
15:15:50 T:140682290751392 NOTICE: m_displayName : HDA Intel PCH
15:15:50 T:140682290751392 NOTICE: m_displayNameExtra: ALC887-VD Analog
15:15:50 T:140682290751392 NOTICE: Device 3
15:15:50 T:140682290751392 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=0
15:15:50 T:140682290751392 NOTICE: m_displayNameExtra: HDMI
15:15:50 T:140682290751392 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:15:50 T:140682290751392 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR
15:15:50 T:140682290751392 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
15:15:50 T:140682290751392 NOTICE: load settings...
15:15:50 T:140682290751392 DEBUG: SECTION:LoadDLL(libcrystalhd.so.3)
15:15:50 T:140682290751392 DEBUG: Loading: libcrystalhd.so.3
15:15:50 T:140682290751392 DEBUG: CrystalHD: device open failed , returning(0xffffffff)
15:15:50 T:140682290751392 DEBUG: CrystalHD: broadcom crystal hd not found
15:15:50 T:140682290751392 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:15:50 T:140682290751392 NOTICE: loading special://masterprofile/guisettings.xml
15:15:50 T:140682290751392 NOTICE: Getting hardware information now...
15:15:50 T:140682290751392 INFO: Using analog output
15:15:50 T:140682290751392 INFO: AC3 pass through is enabled
15:15:50 T:140682290751392 INFO: DTS pass through is disabled
15:15:50 T:140682290751392 INFO: AAC pass through is disabled
15:15:50 T:140682290751392 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:15:50 T:140682290751392 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
15:15:50 T:140682290751392 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
15:15:50 T:140682290751392 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/mms/udp
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
15:15:50 T:140682290751392 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
15:15:50 T:140682290751392 NOTICE: Loaded playercorefactory configuration
15:15:50 T:140682290751392 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:15:50 T:140682290751392 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:15:50 T:140682290751392 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:15:50 T:140682290751392 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:15:50 T:140682290751392 NOTICE: Default DVD Player: dvdplayer
15:15:50 T:140682290751392 NOTICE: Default Video Player: dvdplayer
15:15:50 T:140682290751392 NOTICE: Default Audio Player: paplayer
15:15:50 T:140682290751392 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:15:50 T:140682290751392 NOTICE: Log level changed to 0
15:15:50 T:140682290751392 NOTICE: Loading media sources from special://masterprofile/sources.xml
15:15:50 T:140682290751392 INFO: creating subdirectories
15:15:50 T:140682290751392 INFO: userdata folder: special://masterprofile/
15:15:50 T:140682290751392 INFO: recording folder:
15:15:50 T:140682290751392 INFO: screenshots folder:
15:15:50 T:140682290751392 INFO: thumbnails folder: special://masterprofile/Thumbnails
15:15:50 T:140682290751392 INFO: load language info file: special://xbmc/language/English/langinfo.xml
15:15:50 T:140682290751392 DEBUG: trying to set locale to en_US.UTF-8
15:15:50 T:140682290751392 INFO: global locale set to C
15:15:50 T:140682290751392 INFO: load English language file, from path: special://xbmc/language/
15:15:51 T:140682290751392 DEBUG: POParser: loaded 2686 strings from file /usr/local/share/xbmc/language/English/strings.po
15:15:51 T:140682290751392 INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
15:15:51 T:140682290751392 INFO: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=PCH,DEV=0"
15:15:51 T:140682290751392 INFO: CAESinkALSA::Initialize - Opened device "hdmi:CARD=PCH,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x00"
15:15:51 T:140682290751392 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
15:15:51 T:140682290751392 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
15:15:51 T:140682290751392 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 8192
15:15:51 T:140682290751392 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 8192
15:15:51 T:140682290751392 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 186 ms
15:15:51 T:140682290751392 DEBUG: CSoftAE::InternalOpenSink - ALSA Initialized:
15:15:51 T:140682290751392 DEBUG: Output Device : HDA Intel PCH
15:15:51 T:140682290751392 DEBUG: Sample Rate : 44100
15:15:51 T:140682290751392 DEBUG: Sample Format : AE_FMT_S32NE
15:15:51 T:140682290751392 DEBUG: Channel Count : 2
15:15:51 T:140682290751392 DEBUG: Channel Layout: FL,FR
15:15:51 T:140682290751392 DEBUG: Frames : 2048
15:15:51 T:140682290751392 DEBUG: Frame Samples : 4096
15:15:51 T:140682290751392 DEBUG: Frame Size : 8
15:15:51 T:140682290751392 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 3.0
15:15:51 T:140682290751392 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 16384
15:15:51 T:140682008729344 NOTICE: Thread CSoftAE start, auto delete: false
15:15:51 T:140682008729344 INFO: CSoftAE::Run - Thread Started
15:15:51 T:140682290751392 NOTICE: Running database version Addons15
15:15:51 T:140682290751392 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcpluff-x86_64-linux.so)
15:15:51 T:140682290751392 DEBUG: Loading: /usr/local/lib/xbmc/system/libcpluff-x86_64-linux.so
15:15:51 T:140682290751392 INFO: ADDON: cpluff: 'Could not read plug-in directory /usr/local/lib/xbmc/addons: No such file or directory'
15:15:51 T:140682290751392 DEBUG: LoadMappings - loaded node "Motorola Nyxboard Hybrid"
15:15:51 T:140682290751392 DEBUG: LoadMappings - loaded node "CEC Adapter"
15:15:51 T:140682290751392 DEBUG: LoadMappings - loaded node "Pulse-Eight CEC Adapter"
15:15:51 T:140682290751392 DEBUG: LoadMappings - loaded node "iMON HID device"
15:15:51 T:140682290751392 DEBUG: CPeripheralBusUSB - initialised udev monitor
15:15:51 T:140682290751392 DEBUG: SECTION:LoadDLL(libcec.so.1)
15:15:51 T:140682290751392 DEBUG: Loading: libcec.so.1
############### END LOG FILE ################
Output of lsmod:
root@chronos:~# lsmod
Module Size Used by
nfsd 216170 2
nfs 308313 0
nfs_acl 12511 2 nfs,nfsd
auth_rpcgss 37143 2 nfs,nfsd
fscache 36739 1 nfs
lockd 67306 2 nfs,nfsd
sunrpc 173730 6 lockd,auth_rpcgss,nfs_acl,nfs,nfsd
lm75 12722 0
loop 22641 0
sr_mod 21899 0
cdrom 35401 1 sr_mod
sg 25874 0
snd_hda_codec_hdmi 30768 1
snd_hda_codec_realtek 104857 1
usb_storage 43870 0
snd_hda_intel 26258 0
i915 378445 1
snd_hda_codec 82861 3 snd_hda_intel,snd_hda_codec_realtek,snd_hda_codec_hdmi
snd_hwdep 13189 1 snd_hda_codec
snd_pcm 63904 3 snd_hda_codec,snd_hda_intel,snd_hda_codec_hdmi
drm_kms_helper 31370 1 i915
snd_page_alloc 13003 2 snd_pcm,snd_hda_intel
eeepc_wmi 12564 0
snd_timer 22812 1 snd_pcm
drm 183952 2 drm_kms_helper,i915
asus_wmi 18726 1 eeepc_wmi
r8169 47008 0
acpi_cpufreq 12935 0
i2c_algo_bit 12841 1 i915
psmouse 69265 0
xhci_hcd 73434 0
mperf 12453 1 acpi_cpufreq
i2c_i801 16870 0
sparse_keymap 12760 1 asus_wmi
pcspkr 12579 0
serio_raw 12931 0
coretemp 12898 0
i2c_core 23876 6 i2c_i801,i2c_algo_bit,drm,drm_kms_helper,i915,lm75
evdev 17562 10
rfkill 19012 1 asus_wmi
snd 53063 7 snd_timer,snd_pcm,snd_hwdep,snd_hda_codec,snd_hda_intel,snd_hda_codec_realtek,snd_hda_codec_hdmi
iTCO_wdt 17081 0
iTCO_vendor_support 12704 1 iTCO_wdt
ehci_hcd 40215 0
mii 12675 1 r8169
usbcore 128741 4 ehci_hcd,xhci_hcd,usb_storage
crc32c_intel 12747 0
video 17683 1 i915
processor 28157 1 acpi_cpufreq
button 12937 1 i915
ghash_clmulni_intel 13173 0
cryptd 14517 1 ghash_clmulni_intel
soundcore 13065 1 snd
wmi 13243 1 asus_wmi
usb_common 12354 1 usbcore
ext4 350763 1
crc16 12343 1 ext4
mbcache 13114 1 ext4
jbd2 62115 1 ext4
sd_mod 36136 3
crc_t10dif 12348 1 sd_mod
fan 12674 0
thermal 17383 0
thermal_sys 18040 4 thermal,fan,processor,video
ahci 24997 2
libahci 22860 1 ahci
libata 140630 2 libahci,ahci
scsi_mod 162269 5 libata,sd_mod,usb_storage,sg,sr_mod
Output from lspci:
root@chronos:~# lspci
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation 7 Series Chipset Family LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 09)
root@chronos:~#
