2014-01-04, 19:15
I have a gbox midnight and did a firmware update to 5-6-12 on it and installed the new xbmc frodo 12.3 but now it launches into android media player program first and then I have to go to the program file and select xbmc and not directly into xbmc, It doesn't have an option to launch to xbmc on the startup screen, so, I checked around and it seems there is an older version of xmbc that was made for the gbox ( XBMC Froto 12 Beta for G-Box 12-17-12 ) and that one launches directly into xbmc or gives you the option to launch into xbmc, but the file link is dead on the site that had it and I can't seem to find it anywhere. does anyone know how to modify the boot menu on the android gbox to get it to launch directly into xbmc so I can use the newer 12.3 xbmc or know of where I can find the older file ( XBMC Froto 12 Beta for G-Box 12-17-12)? any help would be greatly appreciated!
