2014-01-04, 19:53
Hey
the addon MyVideo does not work under my XBMC 12.2 on Android. Every stream i try to start raises in an error which says that the playback of one or more files was not possible. The same plugin works fine on windows with same version of XBMC installed. Is it a known problem and are their any solutions for it?
Maybe I only have to install some othe plugins first?
If it is not a common problem I can also upload my log file.
Best regards
Best regards
