Full Version: playercorefactory Help please
Hi all, Loving XBMC very much, I just discovered it. Everything is working great except for one thing.
I have XBMC set to play videos through MPC-HC. This works great for my movies and SOME streatming. But some streaming it doesn't work. It loads up MPC-HC but then doesn't start the video.
I'd like MPC-HC to play my files, but I'd like XBMC to use it's own internal player for streaming. I understand it needs to be set in playercorefactory, but I can't figure it out. Here is my playercorefactory.
PHP Code:
<playercorefactory>
players>
player name="Universal_Player" type="ExternalPlayer" audio="false" video="true">
filename>C:\MPC-HC\mpc-hc.exe</filename>
args>"{1}" /fullscreen</args>
hidexbmc>true</hidexbmc>
hideconsole>true</hideconsole>
warpcursor>none</warpcursor>
player>
players>
rules action="prepend">
Universal Player -->
rule filename="*.*" player="Universal_Player"/>
rules>
playercorefactory
After extensive searching online I've found someone else who wanted the same thing and they were told to add:
PHP Code:
<rules action="prepend">
rule internetstream="false" player="Universal_Player" />
rules
I have added this in it's entirety, and just the "rule" part several times and in several different places, but can't get it to work.
Can anyone help Please?
Why don;t you just use XBMC to play everything directly ? I mean that is what it was designed for...
(2014-01-05, 23:43)Kib Wrote: [ -> ]Why don;t you just use XBMC to play everything directly ? I mean that is what it was designed for...
MPC-HC (Media Player Classic - Home Cinema) allows you to use madVR which renders the video at a higher quality than XBMC's integrated player.
I am also having trouble with DTS Master or Dolby True HD Sound Formats in XBMC.
EDIT: got the sound issue worked out
(2014-01-06, 00:47)jimray Wrote: [ -> ]MPC-HC (Media Player Classic - Home Cinema) allows you to use madVR which renders the video at a higher quality than XBMC's integrated player.
I see more use in getting proper sources than using effects to 'improve' image quality.
I use passthrough audio as well.
I guess for upscaling bad content it might help to use something like MadVR.
MadVR supports not only upscaling but better vsync, display calibration etc. In fact I don't even care about upscaling because I only play high quality content.
It really seems like you have a bee in your bonnet Kib, it's nothing against XBMC, but it's integrated player is inferior to a well calibrated MPC-HC.
