2014-01-06, 22:37
I seen a couple of post with regard to the AMD Radeon drivers. I guess that might be the root cause of my issue but I'd like to run it by you guys first before jumping into a conclusion. I'm want to try out xbmcbuntu on my new build for a HTPC. My build consists of the following,
Motherboard - ASRock FM2A88X-ITX+ (http://www.newegg.com/Product/Product.as...6813157464)
has 6 Sata ports
CPU - AMD A6-6400K Richland (http://www.amazon.com/gp/product/B00CPLG...UTF8&psc=1). It includes APU with Radeon HD 8470D
I'm tryied running xbmcbuntu live (xbmcbuntu-12.2.Intel-AMD.iso on a USB stick) on this build. It comes to this screen and just stays there. The cursur stuck at the top right corner. But I can move the mouse pointer around. Is this an issue because of the Radeon driver?
If I am to install xbmc on this machine what are my options if xbmcbuntu does not work.
has 6 Sata ports
