I've made some edits to th[align=center]e original code if anyone is interested. I wanted to use this for a baby monitor that shows onscreen if the baby is moving. My setup is follows:
- DLink DCS-932L IP Cam which has motion detection.
- When motion is detected, it FTP overwrites a file to my HTPC (two choices with this cam, FTP or Email)
- Using Eventghost with the FTP directory watcher plugin it calls the JSON RPC command for the Security Cam add-on.
This worked well after making some timing choices for the Duration (20s) of the add-on and the Seconds per frame (18s) IP Cam setting for the motion detection FTP process. However, there were still some issues for me.
- Multiple instances of the script would start.
- FTP events caused it to be called twice because directory watcher detects the FTP start and FTP complete as both changes to the directory.
- Hard to manually back out with a million instances running so that I could move about xbmc again.
So I decided to modify the code to detect if there was already an instance running. Also I wanted it to stay on screen if there was continuous motion detected. This is so we can decide if its really necessary to go and be parents or if the baby is just settling.
By no means am I an expert coder... this is my first interaction with Python. Feedback is appreciated!
[/align]
# Import the modules
import os, time, urllib2, xbmc, xbmcaddon, xbmcgui, xbmcvfs
# Constants
ACTION_PREVIOUS_MENU = 10
ACTION_BACKSPACE = 110
ACTION_NAV_BACK = 92
ADD_ON_ID = 'script.securitycam'
# Set plugin variables
__addon__ = xbmcaddon.Addon()
__cwd__ = __addon__.getAddonInfo('path').decode("utf-8")
__icon__ = xbmc.translatePath(os.path.join(__cwd__, 'icon.png').encode("utf-8")).decode("utf-8")
__resource__ = xbmc.translatePath(os.path.join(__cwd__, 'resources').encode("utf-8")).decode("utf-8")
__snapshot_dir__ = xbmc.translatePath(os.path.join(__resource__, 'media', 'snapshots').encode("utf-8")).decode("utf-8")
__time_file__ = xbmc.translatePath(os.path.join(__resource__, 'media').encode("utf-8")).decode("utf-8") '''New Variable'''
# Get settings
url = __addon__.getSetting('url')
username = __addon__.getSetting('username')
password = __addon__.getSetting('password')
width = int(float(__addon__.getSetting('width')))
height = int(float(__addon__.getSetting('height')))
interval = int(float(__addon__.getSetting('interval')))
autoClose = (__addon__.getSetting('autoClose') == 'true')
duration = int(float(__addon__.getSetting('duration')) * 1000)
# Utils
def log(message,loglevel=xbmc.LOGNOTICE):
xbmc.log((ADD_ON_ID + ": " + message).encode('UTF-8','replace'),level=loglevel)
# Classes
class CamPreviewDialog(xbmcgui.WindowDialog):
def __init__(self):
log('CamPreviewDialog Initialized \n', xbmc.LOGDEBUG)
COORD_GRID_WIDTH = 1280
COORD_GRID_HEIGHT = 720
scaledWidth = int(float(COORD_GRID_WIDTH) / self.getWidth() * width)
scaledHeight = int(float(COORD_GRID_HEIGHT) / self.getHeight() * height)
self.image = xbmcgui.ControlImage(COORD_GRID_WIDTH - scaledWidth, COORD_GRID_HEIGHT - scaledHeight, scaledWidth, scaledHeight, __icon__)
self.addControl(self.image)
self.image.setAnimations([('WindowOpen', 'effect=slide start=%d time=1000 tween=cubic easing=in'%(scaledWidth),), ('WindowClose', 'effect=slide end=%d time=1000 tween=cubic easing=in'%(scaledWidth),)])
def start(self, autoClose, duration, interval, url, destination):
log('CamPreviewDialog Started \n', xbmc.LOGDEBUG)
self.isRunning = bool(1)
snapshot = ''
startTime = time.time()
while(not autoClose or (time.time() - startTime) * 1000 <= duration):
if xbmcvfs.exists(snapshot):
os.remove(snapshot)
snapshot = self.downloadSnapshot(url, destination)
if snapshot != '':
self.update(snapshot)
xbmc.sleep(interval)
'''Added following code to check or update the start time'''
try:
log('Opening Time File to check time', xbmc.LOGDEBUG)
file = open(os.path.join(__time_file__, 'timefile.txt'), 'r')
startTime = float(file.read())
log('Start Time is: ' + str(startTime) + ' | Time Left is: ' + str(duration - ((time.time() - startTime) * 1000)), xbmc.LOGDEBUG)
file.close()
except IOError, message:
log('Time File Error:' + str(message), xbmc.LOGDEBUG)
finally:
if not self.isRunning:
break
'''Added following code to successfully delete the file when the camera is done in case it was currently in use'''
log('Removing Time File', xbmc.LOGDEBUG)
while (os.path.exists(os.path.join( __time_file__, 'timefile.txt') )):
try:
os.remove(os.path.join( __time_file__, 'timefile.txt') )
log('Time File Delete Error:' + str(message), xbmc.LOGDEBUG)
self.close()
def downloadSnapshot(self, url, destination):
log('Retreiving Image \n', xbmc.LOGDEBUG)
try:
imgData = urllib2.urlopen(url).read()
filename = snapshot = xbmc.translatePath( os.path.join( destination, 'snapshot' + str(time.time()) + '.jpg' ).encode("utf-8") ).decode("utf-8")
output = open(filename,'wb')
output.write(imgData)
output.close()
return filename
except:
return ''
def onAction(self, action):
log('Received Action: ' + str(action.getId()) + '\n', xbmc.LOGDEBUG)
if action in (ACTION_PREVIOUS_MENU, ACTION_BACKSPACE, ACTION_NAV_BACK):
self.isRunning = bool(0)
self.close()
def update(self, image):
log('Updating Image \n', xbmc.LOGDEBUG)
self.image.setImage(image, bool(0))
'''New Function to write the start time to a file'''
def WriteStartTime():
try:
file = open(os.path.join( __time_file__, 'timefile.txt'), 'w')
log('Writing new start time:' + str(time.time()), xbmc.LOGDEBUG)
file.write (str(time.time()))
file.close()
log('Time File Error:' + message, xbmc.LOGDEBUG)
# Main execution
'''New Execution code to check if there is an instance running already or not'''
if os.path.exists(os.path.join( __time_file__, 'timefile.txt')):
log('Time File Exists', xbmc.LOGDEBUG)
WriteStartTime()
exit()
else:
log('Camera Initial Start', xbmc.LOGDEBUG)
WriteStartTime()
log('AutoClose: [' + str(autoClose) + ']\n', xbmc.LOGDEBUG)
log('Duration: [' + str(duration) + ']\n', xbmc.LOGDEBUG)
log('Interval: [' + str(interval) + ']\n', xbmc.LOGDEBUG)
log('Width: [' + str(width) + ']\n', xbmc.LOGDEBUG)
log('Height: [' + str(height) + ']\n', xbmc.LOGDEBUG)
log('Original URL: [' + url + ']\n', xbmc.LOGDEBUG)
# Add Basic Authentication Headers
if (username is not None and username != ''):
passwordManager = urllib2.HTTPPasswordMgrWithDefaultRealm()
passwordManager.add_password(None, url, username, password)
authhandler = urllib2.HTTPBasicAuthHandler(passwordManager)
opener = urllib2.build_opener(authhandler)
urllib2.install_opener(opener)
# Replace URL agruments
argCount = len(sys.argv)
for i in xrange(1, argCount):
search = '{%d}'%(i - 1)
replace = sys.argv[i]
url.replace(search, replace)
log('Final URL: [' + url + ']\n', xbmc.LOGDEBUG)
xbmcvfs.mkdir(__snapshot_dir__)
camPreview = CamPreviewDialog()
camPreview.show()
camPreview.start(autoClose, duration, interval, url, __snapshot_dir__)
del camPreview
dirs, files = xbmcvfs.listdir(__snapshot_dir__)
for file in files:
log('Delete remaining snapshot: [' + file + ']\n', xbmc.LOGDEBUG)
xbmcvfs.delete(os.path.join(__snapshot_dir__, file))
