Full Version: Security CAM Overlay add-on
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
I can confirm that I have the same isue with the structure using Openelec XBMC Gotham
I'm running the CAM Overlay add-on OK on my OpenElec Gotham. It reports as version 0.0.9
I wrote about my setup here on my blog as I added two cams etc.
Hi, Unfortunately as soon as you try to install from Zip the incorrect structure error is returned so unfortunately your post and blog do not appear relevant to the issue?
Thanks fot the thoughts and response though.
(2014-10-03, 16:37)martinjohn Wrote: [ -> ]Hi, Unfortunately as soon as you try to install from Zip the incorrect structure error is returned so unfortunately your post and blog do not appear relevant to the issue?
If you can get me a debug log of the failed install I can take a look and see if I can figure out what the issue is.
Hi
Maybe something has changed then? I installed the add-on a good while ago now on Gotham v13.0, and have since updated my OpenElec HTPC to v13.1 and then v13.2 etc.
As a test I just downloaded the v0.0.9 CAM overlay add-on again and tried to install it on Gotham v13.2 on my Windows 7 laptop and it installed fine no problems.
So seems to be working OK for me in this instance.
Can this run on Android XBMC?
It should do. It is python. But why don't you try it and report back?
I did try it I just get the icon no cam feed. The URL works in a browser and I can't find the word error in the log I will paste in the log when I get home tonight.
Make sure the URL is getting an image, not a video stream.
(2014-10-03, 16:38)iolaus Wrote: [ -> ]
(2014-10-05, 12:01)cw-kid Wrote: [ -> ]Hi
struggling to get XBMC to log anything with regards to trying to install the addon, I have now changed the installation from Openelec on a PI to Raspbmc on a PI but error persists, Any thoughts?
Hi Guys sorry if this is to much info here is the log from my android device. Can you see anything glaringly obvious?
Many Thanks
NOTICE: -->Python Interpreter Initialized<--
12:53:52 T:1863935400 DEBUG: CPythonInvoker(22, /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.skinshortcuts/default.py): the source file to load is "/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.skinshortcuts/default.py"
12:53:52 T:1863935400 DEBUG: CPythonInvoker(22, /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.skinshortcuts/default.py): setting the Python path to /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.skinshortcuts:/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simplejson/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/script.module.pil/lib:/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/lib:/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.unidecode/lib:/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.requests/lib:/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.grab.fanart/default.py:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/xbmc.debug/:/:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-dynload
12:53:52 T:1863935400 DEBUG: CPythonInvoker(22, /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.skinshortcuts/default.py): entering source directory /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.skinshortcuts
12:53:52 T:1863935400 DEBUG: CPythonInvoker(22, /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.skinshortcuts/default.py): instantiating addon using automatically obtained id of "script.skinshortcuts" dependent on version 2.14.0 of the xbmc.python api
12:53:52 T:1871366264 DEBUG: virtual bool CImageLoader:Big GrinoWork() - took 176 ms to load special://masterprofile/Thumbnails/c/c0a3e2b2.jpg
12:53:52 T:1863935400 DEBUG: script.skinshortcuts: script version 0.4.0 started
12:53:52 T:1863935400 DEBUG: script.skinshortcuts: Profile found: Master user (special://masterprofile/)
12:53:52 T:1863935400 DEBUG: script.skinshortcuts: Menu is up to date
12:53:52 T:1863935400 DEBUG: script.skinshortcuts: script stopped
12:53:52 T:1863935400 INFO: CPythonInvoker(22, /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.skinshortcuts/default.py): script successfully run
12:53:52 T:1863935400 INFO: Python script stopped
12:53:52 T:1863935400 DEBUG: Thread LanguageInvoker 1863935400 terminating
12:53:53 T:1762066200 DEBUG: Keyboard: scancode: 0x15, sym: 0x0114, unicode: 0x0000, modifier: 0x0
12:53:53 T:1762066200 DEBUG: bool CApplication::OnKey(const CKey&): left (0xf082) pressed, action is Left
12:53:53 T:1872362696 DEBUG: int XFILE::CSMBDirectory::OpenDir(const CURL&, CStdString&) - Using authentication url smb://USERNAMETongueASSWORD@PCMCG/Downloads/Background%20Pics/Apps
12:53:53 T:1762066200 DEBUG: Keyboard: scancode: 0x42, sym: 0x000d, unicode: 0x000a, modifier: 0x0
12:53:53 T:1762066200 DEBUG: bool CApplication::OnKey(const CKey&): return (0xf00d) pressed, action is Select
12:53:53 T:1762066200 DEBUG: Activating window ID: 10001
12:53:54 T:1762066200 DEBUG: ------ Window Deinit (Home.xml) ------
12:53:54 T:1762066200 DEBUG: CAndroidAppDirectory::GetDirectory: apps
12:53:54 T:1762066200 DEBUG: ------ Window Init (MyPrograms.xml) ------
12:53:54 T:1762066200 DEBUG: Window MyPrograms.xml was already loaded
12:53:54 T:1762066200 DEBUG: Alloc resources: 0.64m
12:53:54 T:1762066200 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/executable/)
12:53:54 T:1762066200 DEBUG: ParentPath = [addons://sources/executable/]
12:53:54 T:2012208904 NOTICE: Thread BackgroundLoader start, auto delete: false
12:53:54 T:1871366264 DEBUG: int XFILE::CSMBDirectory::OpenDir(const CURL&, CStdString&) - Using authentication url smb://USERNAMETongueASSWORD@PCMCG/Downloads/Background%20Pics/Apps
12:53:54 T:2012208904 DEBUG: Thread BackgroundLoader 2012208904 terminating
12:53:54 T:1843814864 DEBUG: int XFILE::CSMBDirectory::OpenDir(const CURL&, CStdString&) - Using authentication url smb://USERNAMETongueASSWORD@PCMCG/Downloads/Background%20Pics/Apps
12:53:54 T:1893576344 DEBUG: SECTION:LoadDLL(libImageLib-arm.so)
12:53:54 T:1893576344 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-1/libImageLib-arm.so
12:53:55 T:1762066200 DEBUG: Keyboard: scancode: 0x14, sym: 0x0112, unicode: 0x0000, modifier: 0x0
12:53:55 T:1762066200 DEBUG: bool CApplication::OnKey(const CKey&): down (0xf081) pressed, action is Down
12:53:55 T:1762066200 DEBUG: Keyboard: scancode: 0x16, sym: 0x0113, unicode: 0x0000, modifier: 0x0
12:53:55 T:1762066200 DEBUG: bool CApplication::OnKey(const CKey&): right (0xf083) pressed, action is Right
12:53:56 T:1762066200 DEBUG: Keyboard: scancode: 0x42, sym: 0x000d, unicode: 0x000a, modifier: 0x0
12:53:56 T:1762066200 DEBUG: bool CApplication::OnKey(const CKey&): return (0xf00d) pressed, action is Select
12:53:56 T:1863935400 NOTICE: Thread LanguageInvoker start, auto delete: false
12:53:56 T:1863935400 INFO: initializing python engine.
12:53:56 T:1863935400 DEBUG: CPythonInvoker(23, /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.securitycam/default.py): start processing
12:53:56 T:1863935400 NOTICE: -->Python Interpreter Initialized<--
12:53:56 T:1863935400 DEBUG: CPythonInvoker(23, /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.securitycam/default.py): the source file to load is "/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.securitycam/default.py"
12:53:56 T:1863935400 DEBUG: CPythonInvoker(23, /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.securitycam/default.py): setting the Python path to /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.securitycam:/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simplejson/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/script.module.pil/lib:/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/lib:/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.unidecode/lib:/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.requests/lib:/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.grab.fanart/default.py:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/xbmc.debug/:/:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.xbmc-1.apk/assets/python2.6/lib/python2.6/lib-dynload
12:53:56 T:1863935400 DEBUG: CPythonInvoker(23, /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.securitycam/default.py): entering source directory /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.securitycam
12:53:56 T:1863935400 DEBUG: CPythonInvoker(23, /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.securitycam/default.py): instantiating addon using automatically obtained id of "script.securitycam" dependent on version 2.14.0 of the xbmc.python api
12:53:56 T:1863935400 DEBUG: script.securitycam: AutoClose: [True]
12:53:56 T:1863935400 DEBUG: script.securitycam: Duration: [10000]
12:53:56 T:1863935400 DEBUG: script.securitycam: Interval: [200]
12:53:56 T:1863935400 DEBUG: script.securitycam: Width: [480]
12:53:56 T:1863935400 DEBUG: script.securitycam: Height: [480]
12:53:56 T:1863935400 DEBUG: script.securitycam: Original URL: [http://admin:[email protected]:99/snapshot.cgi]
12:53:56 T:1863935400 DEBUG: script.securitycam: Final URL: [http://admin:[email protected]:99/snapshot.cgi]
12:53:56 T:1863935400 DEBUG: script.securitycam: CamPreviewDialog Initialized
12:53:56 T:1762066200 DEBUG: ------ Window Init () ------
12:53:56 T:1762066200 DEBUG: Alloc resources: 0.01ms (0.00 ms skin load)
12:53:56 T:1863935400 DEBUG: script.securitycam: CamPreviewDialog Started
12:53:56 T:1863935400 DEBUG: script.securitycam: Retreiving Image
12:54:06 T:1863935400 DEBUG: Previous line repeats 48 times.
12:54:06 T:1863935400 INFO: CPythonInvoker(23, /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.securitycam/default.py): script successfully run
12:54:06 T:1863935400 INFO: Python script stopped
12:54:06 T:1863935400 DEBUG: Thread LanguageInvoker 1863935400 terminating
12:54:07 T:1762066200 DEBUG: ------ Window Deinit () ------
12:54:26 T:1762066200 DEBUG: SECTION:UnloadDelayed(DLL: libImageLib-arm.so)
12:54:26 T:1762066200 DEBUG: Unloading: libImageLib-arm.so
12:54:46 T:1871366264 DEBUG: Thread JobWorker 1871366264 terminating (autodelete)
12:54:46 T:1843814864 DEBUG: Thread JobWorker 1843814864 terminating (autodelete)
12:54:46 T:1893576344 DEBUG: Thread JobWorker 1893576344 terminating (autodelete)
12:54:46 T:1872362696 DEBUG: Thread JobWorker 1872362696 terminating (autodelete)
12:55:26 T:1762066200 NOTICE: Samba is idle. Closing the remaining connections
Any ideas anyone? I have been playing but can't get it to work :'(
Firstly, does the url work in a browser?
I bashed my head against the URL, the ispy links adon't work for my D-Link DCS-2132LB1. Ultimately it was MFKinSINY's post that led me to investigate the video source within the web configuration window and I discovered that it was http://<IPADDRESS>/dms?nowprofileid=1
Hi
The link in the log works fine in a browser on the same device.
