(2023-03-06, 00:50)Dweber85rc Wrote: [ -> ]Is there a way to run either a second instance of this addon or a way to edit this one to support more than 4 cameras?
It looks like it is hardcoded in the addon default.py file line 39:
MAXCAMS = 4
I think you can simply change this to a bigger number and give it a shot.
Thanks,
Jeff
Hi, I am using this addon daily on all my Kodi installations with the latest Kodi versions.
I do not remember where I downloaded and how I modified the addon ( I use it since Kodi 17 ) ... but I have the addons in zip file that needs to be extracted to the "addons" folder manually, and then to be enabled in Kodi ( and complete the configuration ).
If the rules of the forum allow, I could share them from my dropbox ...
I've run into a bug when trying to fill the entire screen with 4 cameras using the square layout on a 4K display.
The righthand column pushes down a quarter of its total height (diagrammed below).
______
| |_____
| 1 | |
|_____| 2 |
| |_____|
| 3 | |
|_____| 4 |
|_____|
I tried fiddling with the default.py file but I couldn't quite wrap my mind around the size variables and math for dividing and multiplying to correct the layout issue.
Here are the add-on's settings:
Window Width = 640
Window Height = 360
Alignment: Square: left (or right) top
Padding (in Pixels): 0
Aspect Ratio: (any)
Could anyone lend a hand in this regard? It would be much appreciated, thanks!
