Full Version: Security CAM Overlay add-on
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
just a WAG here, but can you get a still image from http://192.168.1.1:8080/?action=stream&ext=.jpg (note the missing m from the ext= param)
I get the same results with ext=.jpg and ext=.mjpg param.
21:47:41 T:3040239616 DEBUG: Addon script.securitycam requires xbmc.python version 2.0 which is not available
Are this dependency issue for ver13 going to be fixed anytime soon?
(2014-01-21, 11:47)Javlin Wrote: [ -> ]Not sure if a latest version of gotham has broken this addon. I get a picture when I trigger the addon but it does not refresh or every 8 seconds it flashes. I have tried 50 to 1000 milliseconds. Is there anything on my end that would effect refresh rate? The old plugin seemed to refresh quicker. Mite have to revert if I can find it.
(2014-01-21, 12:16)warlion Wrote: [ -> ]yeah over gotham dont refresh the img, im waiting for the fix also
(2014-01-24, 00:11)TheEndless Wrote: [ -> ]21:47:41 T:3040239616 DEBUG: Addon script.securitycam requires xbmc.python version 2.0 which is not available
I've added a new Gotham version of the plug-in which can be downloaded from the link in the OP. I'm hoping that this update will correct both the "image doesn't refresh" and "xbmc.python version 2.0" issues. I do not have a Gotham install to test this with so please let me know how it goes.
Reporting the new 0.6 for Gotham with a error
PHP Code:
EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
NOTEIGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.NameError'>
Error Contents: global name 'false' is not defined
                                            Traceback
(most recent call last):
File "C:\Users\Fernando\AppData\Roaming\XBMC\addons\script.securitycam\default.py"line 95in <module>
camPreview.start(autoClosedurationintervalurl__snapshot__)
File "C:\Users\Fernando\AppData\Roaming\XBMC\addons\script.securitycam\default.py"line 51in start
                                                self
.update(destination)
File "C:\Users\Fernando\AppData\Roaming\XBMC\addons\script.securitycam\default.py"line 65in update
                                                self
.image.setImage(imagefalse)
NameError: global name 'false' is not defined
-->End of Python script error report<--
12:49:13 T:8160   DEBUG: ------ Window Init (DialogKaiToast.xml) ------
(2014-01-24, 20:56)warlion Wrote: [ -> ]Reporting the new 0.6 for Gotham with a error
PHP Code:
                                            Traceback
                                                self
                                                self
And the perils of developing without testing reveal themselves immediately. Uploaded a new version (v0.0.7) which I believe should correct this.
Lol we get a empty folder
(2014-01-24, 21:08)warlion Wrote: [ -> ]Lol we get a empty folder
Sorry, Google Drive is acting up. Should be uploaded shortly.
Thanks iolaus
V. 0.7 for Gotham the error is gone but still don't refresh
The install now works fine on a default Gotham (havn"t tried the full functionallity yet). But on my RaspPi Nightly Gotham 131223 I get yet the next error, same but for new version.
22:24:13 T:3040239616 DEBUG: Addon script.securitycam requires xbmc.python version 2.1 which is not available
Fixable?
Hello,
I've been fiddling around for several hours already, but with poor results.
As I'm on XBMC version 12.3, I've installed v0.0.5. With no camera defined, if I launch de add-on, I see an error message which indicates "script failed! : script.securitycam".
This is what the logging looks like:
01:08:08 T:1071054232   DEBUG: XBMCPureController: Button press remoteAction = 5 originator = 1
01:08:08 T:109051904   DEBUG: CWinEventsIOS: Button press keyID = 5
01:08:08 T:109051904    INFO: initializing python engine.
01:08:08 T:109051904   DEBUG: new python thread created. id=5
01:08:08 T:804786176   DEBUG: Python thread: start processing
01:08:08 T:804786176  NOTICE: -->Python Interpreter Initialized<--
01:08:08 T:804786176   DEBUG: Process - The source file to load is /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/default.py
01:08:08 T:804786176   DEBUG: Process - Setting the Python path to /var/mobile/Library/Preferences/XBMC/addons/script.securitycam:/var/mobile/Library/Preferences/XBMC/addons/script.module.pyamf/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.simplejson/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.beautifulsoup/lib:/private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/script.module.pil/lib:/var/mobile/Library/Preferences/XBMC/addons/script.common.plugin.cache/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.simple.downloader/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.requests/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.mechanize/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.parsedom/lib:/var/stash/Applications/XBMC.frappliance/Frameworks:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python26.zip:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-darwin:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-mac:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-mac/lib-scriptpackages:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-tk:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-old:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-dynload:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/site-packages:
01:08:08 T:804786176   DEBUG: Process - Entering source directory /var/mobile/Library/Preferences/XBMC/addons/script.securitycam
01:08:08 T:804786176   DEBUG: Instantiating addon using automatically obtained id of "script.securitycam" dependent on version 2.0 of the xbmc.python api
01:08:09 T:804786176   DEBUG: script.securitycam: AutoClose: [True]
01:08:09 T:804786176   DEBUG: script.securitycam: Duration: [15000]
01:08:09 T:804786176   DEBUG: script.securitycam: Interval: [500]
01:08:09 T:804786176   DEBUG: script.securitycam: Width: [480]
01:08:09 T:804786176   DEBUG: script.securitycam: Height: [480]
01:08:09 T:804786176   DEBUG: script.securitycam: Original URL: []
01:08:09 T:804786176   DEBUG: script.securitycam: Final URL: []
01:08:09 T:804786176   DEBUG: script.securitycam: CamPreviewDialog Initialized
01:08:09 T:109051904   DEBUG: ------ Window Init () ------
01:08:09 T:804786176   DEBUG: script.securitycam: CamPreviewDialog Started
01:08:09 T:804786176   DEBUG: script.securitycam: Retreiving Image
01:08:09 T:109051904   DEBUG: ------ Window Init (DialogKaiToast.xml) ------
01:08:09 T:804786176    INFO: Python script stopped
01:08:09 T:109051904   DEBUG: waiting for python thread 5 (/var/mobile/Library/Preferences/XBMC/addons/script.securitycam/default.py) to stop
01:08:09 T:109051904   DEBUG: python thread 5 (/var/mobile/Library/Preferences/XBMC/addons/script.securitycam/default.py) destructed
01:08:09 T:109051904   DEBUG: ------ Window Deinit () ------
Now things get a little worse. If I now configure my Foscam W9821 v2 with one valid string (I've managed to get the feed and checked it with my browser), XBMC becomes unresponsive (it does not freeze because I see the overlaid log location and CPU consumption displayed and continuously changing)
01:03:27 T:1071054232   DEBUG: XBMCPureController: Button press remoteAction = 5 originator = 1
01:03:27 T:132698112   DEBUG: CWinEventsIOS: Button press keyID = 5
01:03:27 T:132698112    INFO: initializing python engine.
01:03:27 T:132698112   DEBUG: new python thread created. id=5
01:03:27 T:138780672   DEBUG: Python thread: start processing
01:03:27 T:138780672  NOTICE: -->Python Interpreter Initialized<--
01:03:27 T:138780672   DEBUG: Process - The source file to load is /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/default.py
01:03:27 T:138780672   DEBUG: Process - Setting the Python path to /var/mobile/Library/Preferences/XBMC/addons/script.securitycam:/var/mobile/Library/Preferences/XBMC/addons/script.module.pyamf/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.simplejson/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.beautifulsoup/lib:/private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/script.module.pil/lib:/var/mobile/Library/Preferences/XBMC/addons/script.common.plugin.cache/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.simple.downloader/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.requests/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.mechanize/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.parsedom/lib:/var/stash/Applications/XBMC.frappliance/Frameworks:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python26.zip:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-darwin:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-mac:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-mac/lib-scriptpackages:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-tk:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-old:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-dynload:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/site-packages:
01:03:27 T:138780672   DEBUG: Process - Entering source directory /var/mobile/Library/Preferences/XBMC/addons/script.securitycam
01:03:27 T:138780672   DEBUG: Instantiating addon using automatically obtained id of "script.securitycam" dependent on version 2.0 of the xbmc.python api
01:03:28 T:138780672   DEBUG: script.securitycam: AutoClose: [True]
01:03:28 T:138780672   DEBUG: script.securitycam: Duration: [15000]
01:03:28 T:138780672   DEBUG: script.securitycam: Interval: [500]
01:03:28 T:138780672   DEBUG: script.securitycam: Width: [480]
01:03:28 T:138780672   DEBUG: script.securitycam: Height: [480]
01:03:28 T:138780672   DEBUG: script.securitycam: Original URL: [http://192.168.1.13/cgi-bin/CGIStream.cgi?cmd=GetMJStream]
01:03:28 T:138780672   DEBUG: script.securitycam: Final URL: [http://192.168.1.13/cgi-bin/CGIStream.cgi?cmd=GetMJStream]
01:03:28 T:138780672   DEBUG: script.securitycam: CamPreviewDialog Initialized
01:03:28 T:132698112   DEBUG: ------ Window Init () ------
01:03:28 T:138780672   DEBUG: script.securitycam: CamPreviewDialog Started
01:03:28 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:28 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:28 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:28 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:28 T:132698112   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-arm-osx.so)
01:03:28 T:132698112   DEBUG: Loading: /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/system/ImageLib-arm-osx.so
01:03:28 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:28 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:29 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:29 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:29 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:29 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:29 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:29 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:30 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:30 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:30 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:30 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:30 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:30 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:31 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:31 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:31 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:31 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:31 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:31 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:32 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:32 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:32 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:32 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:32 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:32 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:33 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:33 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:33 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:33 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:33 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:33 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:34 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:34 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:34 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:34 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:34 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:34 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:35 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:35 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:35 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:35 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:35 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:35 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:36 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:36 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:36 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:36 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:36 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:36 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:37 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:37 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:37 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:37 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:37 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:37 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:38 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:38 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:38 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:38 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:38 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:38 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:39 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:39 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:39 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:39 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:39 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:39 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:40 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:40 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:40 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:40 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:40 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:40 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:41 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:41 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:41 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:41 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:41 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:41 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:42 T:138780672   DEBUG: script.securitycam: Updating Image
01:03:42 T:132698112 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
01:03:42 T:132698112   DEBUG: LoadFromFileInternal - Load of /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg failed. Falling back to ImageLib
01:03:42 T:132698112    INFO:   msg: PICTURE::LoadImage: Unable to open image: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg Error: (60)
01:03:42 T:132698112   ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/script.securitycam/resources/media/temp.jpg
01:03:42 T:138780672   DEBUG: script.securitycam: Retreiving Image
01:03:43 T:138780672    INFO: Scriptresult: Success
01:03:43 T:138780672    INFO: Python script stopped
01:03:43 T:132698112   DEBUG: waiting for python thread 5 (/var/mobile/Library/Preferences/XBMC/addons/script.securitycam/default.py) to stop
01:03:43 T:132698112   DEBUG: python thread 5 (/var/mobile/Library/Preferences/XBMC/addons/script.securitycam/default.py) destructed
01:03:44 T:132698112   DEBUG: ------ Window Deinit () ------
01:04:11 T:132698112  NOTICE: AFP is idle. Closing the remaining connections.
01:04:13 T:132698112   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-arm-osx.so)
01:04:13 T:132698112   DEBUG: Unloading: ImageLib-arm-osx.so
I would appreciate it if you could give me a hand configuring this.
I probably should upgrade the whole AppleTV itself because I'm still on iOS 5.0.2. But on the other hand, I assume that as long as I'm current running the latest v12 version of XBMC, AppleTV's firmware should not play that much of a big roll, right?
Thanks in advance,
I am trying to install 0.0.7 on gotham alpha 12 and I get a dialog box saying "dependencies not met, contact the author"
Updating xbmc to see if something later has the required dependency.
Now i turn on debugging and see it wants xbmc python 2.1.
OK updating xbmc to 13.0~git20140124.0500-b3b79dd-0precise didn't fix it.
17:14:29 T:140582996957056   DEBUG: Addon script.securitycam requires xbmc.python version 2.1 which is not available
@nickr, try editing addon.xml and change the required version from 2.1 to 2.1.0. It should be the same, but maybe linux isn't liking the truncated notation?
