Full Version: $VAR[] to position an image?
I'm trying to use a var to position an image. The most basic trial doesn't work:
<control type="image">
    <left>$VAR[Thingumy]</left>
    <top>570</top>
    <width>50</width>
    <height>50</height>
    <texture>somepic.png</texture>
</control>
<variable name="Thingumy">
    <value>100</value>
</variable>
I know the variable is being set because I can change its value for the texture name and use it in the <texture>, and it works fine.
Any ideas?
Not supported for positions
Variables don't work with integer values. Only strings are supported atm. Don't know if pieh is working on it but I wouldn't wait for support anytime soon.
OK That totally blows my understanding of how $VARs work.
Why does the renderer care where a $VAR is used? Shouldn't it just scan for all uses of $VAR and substitute values?
Why does the renderer care what type a $VAR has? In my mind a $VAR value is just a piece of data.
Anyway, thanks for the clarification.
(2014-01-08, 14:52)powlo Wrote: [ -> ]Why does the renderer care what type a $VAR has? In my mind a $VAR value is just a piece of data.
Second this.
I also think that the renderer shouldn't care where or how the $VAR is used, it should be a (fairly simple) substitution-type mechanism.
(2014-01-07, 22:29)`Black Wrote: [ -> ]Variables don't work with integer values. Only strings are supported atm. Don't know if pieh is working on it but I wouldn't wait for support anytime soon.
I've tried this on another use-case that involves strings, still no luck.
My case is about displaying different items from the Skin Widgets service. Something like this:
PHP Code:
<item id="1">
visible>!IsEmpty(Window.Property($VAR[itemtype].1.File))</visible>
label>$INFO[Window.Property($VAR[itemtype].1.Title)]</label>
onclick>PlayMedia($ESCINFO[Window(Home).Property($VAR[itemtype].1.File)])</onclick>
item>
variable name="itemtype">
value condition="Skin.HasSetting(itemtype2)">RandomEpisode</value>
value>RecentEpisode</value>
variable
I want to use user-defined settings to say if I show recent or random items.
Is this possible currently?
If not - has anyboy figured a workaround for this? (other than copy-pasting the entire block twice)
"The renderer" is a shit load of code. I'd be happy if someone wishes to improve it.
$VAR is evaluated at runtime (i.e. per frame). It doesn't work everywhere for just that reason, as not everything is queried at runtime.
(2014-01-27, 21:11)EtgarDizz Wrote: [ -> ]
PHP Code:
<item id="1">
item>
variable
This is something I will love to see
Second this.
PHP Code:
<item id="1">
item>
variable
Just use conditional includes - one for Recent and one for Random items - and then fill each include with all the relevant items. this is exactly how I do it for Alaska HD.
@powlo - why not just use a conditional slide animation with time="0" to reposition the control -- e.g.
    <width>50</width>
    <height>50</height>
    <animation effect="slide" start="0" end="100,0" time="0" condition="Condition1">Conditional</animation>
    <animation effect="slide" start="0" end="200,100" time="0" condition="Condition2">Conditional</animation>
    <animation effect="slide" start="0" end="500,100" time="0" condition="Condition3">Conditional</animation>
</control>
(2014-01-27, 23:43)Hitcher Wrote: [ -> ]Just use conditional includes - one for Recent and one for Random items - and then fill each include with all the relevant items. this is exactly how I do it for Alaska HD.
Ok, I see how that would help to clean the code... But it still means I will have to have two copies of the same block, with the only difference being the Random/Recent bit...
... and once I want to add an option for "Recommended"... three copies of the same block. And so on.
It's literally a Copy/Paste/Find/Replace job though.
(2014-01-28, 19:11)Hitcher Wrote: [ -> ]It's literally a Copy/Paste/Find/Replace job though.
RoflRoflRoflRoflRoflRofl
Not to take away from the sheer joy of search/replace (especially when using regular expressions for the job)...
Wasn't quite what I meant by "workaround". I'm trying to avoid having huge files with redundant code in them.
Would be nice if someone figured out a creative way to accomplish this.
I wouldn't worry as they'll have no impact on performance, in fact using conditional includes are better for performance as they're loaded on window load whereas variables are checked every screen refresh.
