Full Version: Overkill? or just right
Hello everybody Smile
i have decided to buy a mini computer to use with xbmc, and is what you call a noob Tongue
it will be used with a usb hard drive to stream hd movies and series plus some navi x
i have found this option. please tell me if it will do or if it is to much for "just" a streaming pc
the pc: http://www.hardwarehouse.de/product_info...RE-I7.html
with these ram: http://www.hardwarehouse.de/product_info...-CL11.html
and hard drive http://www.bj-trading.dk/bjshop/default....934&f=edbp
Cheers Smile
(2014-01-08, 02:42)kiroi Wrote: [ -> ]Hello everybody Smile
the pc: http://www.hardwarehouse.de/product_info...-CL11.html
Cheers Smile
A little to much cheers I guess, you've linked twice to the memory Wink
sorry. its been fixed Wink
If you don't need 3D http://www.hardwarehouse.de/product_info...RAPHI.html will be enough together with 4GB RAM and a 64GB SSD.
(2014-01-08, 09:42)CaptainPsycho Wrote: [ -> ]If you don't need 3D http://www.hardwarehouse.de/product_info...RAPHI.html will be enough together with 4GB RAM and a 64GB SSD.
But what if i want 3d? Big Grin
(2014-01-08, 14:48)kiroi Wrote: [ -> ]
http://www.hardwarehouse.de/product_info...iner-.html
(2014-01-08, 15:08)CaptainPsycho Wrote: [ -> ]
Thank you so much for the help Smile
Or cheaper yet - http://www.hardwarehouse.de/product_info...iner-.html
Not sure about 3d content on it, although given it can decode 4k content I would think it should handle it
Or if you can live with the Thunderbold interface (I can), this is a real bargain; http://www.hardwarehouse.de/product_info...bolt-.html
It can handle all kinds of 3D formats, that I have already tested Smile
It doesn't have ethernet port but there is a hdmi out.
(2014-01-08, 17:14)xbs08 Wrote: [ -> ]It doesn't have ethernet port but there is a hdmi out.
Maybe one should Google for the possibilities of that Thunderbolt interface? I use the item below;
I know the possibilities but i thought it should be mentioned in the bargain Wink
Prefer this: http://www.smart.sk/intel-nuc-dn2820-cel...-sata-lan/
Thats what i did, i mentioned it specific in my reply, but even with the extra costs of the Thunderbold to (10Gbit)LAN adapter, its still a bargain, or maybe I'm just mistaken?
No, your are right. It is a bargain even with the addional cost.
(2014-01-08, 17:59)p750mmx Wrote: [ -> ]Thats what i did, i mentioned it specific in my reply, but even with the extra costs of the Thunderbold to (10Gbit)LAN adapter, its still a bargain, or maybe I'm just mistaken?
its a bargain!
+1 for the nuc
