Thanks for taking the time to look into my problem....
Quote:There are some incompatibilities with some NAS boxes.
The Vgear Landisk NAS has been working fine and I don't have a problem with the builds using up to CVS 07-Jan-06. Something changed after that build in XBMC which stopped it working correctly.
I haven't been able to find any builds between 07-Jan-06 and 09-Aug-06 but whatever broke it happended between those two dates.
elupus - I will try and capture smb using ethereal soon. I was searching the cvs repository for smb related information and found CVS Revision 1.2718 29-Jun-06 where a problem with % and spaces in the names was causing a problem and it was fixed.. Please don't take this the wrong way, but could that CVS be the cause of my problem?
Thanks again,
Bruce
15:44:52 M: 39329792 DEBUG: CGUIMediaWindow::GetDirectory (smb://192.168.0.10/Net-250G_01/The Worlds Fastest Indian/)
15:44:52 M: 39329792 DEBUG: ParentPath = [smb://192.168.0.10/Net-250G_01/]
15:44:52 M: 39329792 DEBUG: DIRECTORY::CSMBDirectory::OpenDir - Using authentication url smb://192.168.0.10/Net-250G_01/The%20Worlds%20Fastest%20Indian
15:44:52 M: 39329792 INFO: smb: parsed path: fname='smb://192.168.0.10/Net-250G_01/The%20Worlds%20Fastest%20Indian' server='192.168.0.10' share='Net-250G_01' path='The Worlds Fastest Indian' options=''
15:44:52 M: 39329792 INFO: smb: smbc_check_options(): server='192.168.0.10' share='Net-250G_01' path='The Worlds Fastest Indian' options=''
15:44:52 M: 39329792 INFO: smb: size=136
15:44:52 M: 39329792 INFO: smb: smb_com=0x32
15:44:52 M: 39329792 INFO: smb: smb_rcls=0
15:44:52 M: 39329792 INFO: smb: smb_reh=0
15:44:52 M: 39329792 INFO: smb: smb_err=0
15:44:52 M: 39329792 INFO: smb: smb_flg=8
15:44:52 M: 39329792 INFO: smb: smb_flg2=34817
15:44:52 M: 39329792 INFO: smb: smb_tid=1
15:44:52 M: 39329792 INFO: smb: smb_pid=1
15:44:52 M: 39329792 INFO: smb: smb_uid=0
15:44:52 M: 39329792 INFO: smb: smb_mid=12
15:44:52 M: 39329792 INFO: smb: smt_wct=15
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 0]= 68 (0x44)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 1]= 0 (0x0)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 2]= 10 (0xA)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 3]= 2920 (0xB68)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 4]= 0 (0x0)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 5]= 0 (0x0)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 6]= 0 (0x0)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 7]= 0 (0x0)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 8]= 0 (0x0)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 9]= 68 (0x44)
15:44:52 M: 39329792 INFO: smb: smb_vwv[10]= 68 (0x44)
15:44:52 M: 39329792 INFO: smb: smb_vwv[11]= 0 (0x0)
15:44:52 M: 39329792 INFO: smb: smb_vwv[12]= 136 (0x88)
15:44:52 M: 39329792 INFO: smb: smb_vwv[13]= 1 (0x1)
15:44:52 M: 39329792 INFO: smb: smb_vwv[14]= 1 (0x1)
15:44:52 M: 39329792 INFO: smb: smb_bcc=71
15:44:52 M: 39329792 INFO: smb: [000] 00 44 20 16 00 56 05 06 00 01 00 00 00 00 00 54 .D ..V.. .......T
15:44:52 M: 39329792 INFO: smb: [010] 00 68 00 65 00 20 00 57 00 6F 00 72 00 6C 00 64 .h.e. .W .o.r.l.d
15:44:52 M: 39329792 INFO: smb: [020] 00 73 00 20 00 46 00 61 00 73 00 74 00 65 00 73 .s. .F.a .s.t.e.s
15:44:52 M: 39329792 INFO: smb: [030] 00 74 00 20 00 49 00 6E 00 64 00 69 00 61 00 6E .t. .I.n .d.i.a.n
15:44:52 M: 39329792 INFO: smb: [040] 00 5C 00 2A 00 00 00 .\.*...
15:44:52 M: 39329792 INFO: smb: write_socket(-803176440,140)
15:44:52 M: 39329792 INFO: smb: write_socket(-803176440,140) wrote 140
15:44:52 M: 39329792 INFO: smb: got smb length of 219
15:44:52 M: 39329792 INFO: smb: size=219
15:44:52 M: 39329792 INFO: smb: smb_flg=136
15:44:52 M: 39329792 INFO: smb: smt_wct=10
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 0]= 10 (0xA)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 1]= 154 (0x9A)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 2]= 0 (0x0)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 3]= 10 (0xA)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 4]= 55 (0x37)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 6]= 154 (0x9A)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 7]= 65 (0x41)
15:44:52 M: 39329792 INFO: smb: smb_vwv[ 9]= 0 (0x0)
15:44:52 M: 39329792 INFO: smb: smb_bcc=164
15:44:52 M: 39329792 INFO: smb: [000] 00 00 03 00 01 00 00 00 9A 00 00 00 00 00 54 54 ........ ......TT
15:44:52 M: 39329792 INFO: smb: [010] 22 45 54 54 22 45 54 54 22 45 00 00 00 00 00 00 "ETT"ETT "E......
15:44:52 M: 39329792 INFO: smb: [020] 00 00 10 00 04 72 2E 00 00 00 01 00 00 00 54 54 .....r.. ......TT
15:44:52 M: 39329792 INFO: smb: [030] 22 45 54 54 22 45 54 54 22 45 00 00 00 00 00 00 "ETT"ETT "E......
15:44:52 M: 39329792 INFO: smb: [040] 00 00 10 00 06 69 2E 00 2E 00 00 00 02 00 00 00 .....i.. ........
15:44:52 M: 39329792 INFO: smb: [050] 1E 2C 43 44 1E 2C 43 44 1E 2C 43 44 00 78 C9 2B .,CD.,CD .,CD.x.+
15:44:52 M: 39329792 INFO: smb: [060] 00 78 C9 2B 00 00 3C 47 54 00 68 00 65 00 20 00 .x.+..<G T.h.e. .
15:44:52 M: 39329792 INFO: smb: [070] 57 00 6F 00 72 00 6C 00 64 00 73 00 20 00 46 00 W.o.r.l. d.s. .F.
15:44:52 M: 39329792 INFO: smb: [080] 61 00 73 00 74 00 65 00 73 00 74 00 20 00 49 00 a.s.t.e. s.t. .I.
15:44:52 M: 39329792 INFO: smb: [090] 6E 00 64 00 69 00 61 00 6E 00 2E 00 61 00 76 00 n.d.i.a. n...a.v.
15:44:52 M: 39329792 INFO: smb: [0A0] 69 00 00 00 i...
