2014-01-09, 18:50
(2013-12-04, 21:07)`Black Wrote: [ -> ](2013-11-11, 22:14)ronie Wrote: [ -> ]2013-11-11 Add textbox to OK, YesNo and Progress dialogs
The textbox doesn't auto-size, does it? While I agree that a textbox is better than labels, I won't want to use it in my skin as long as it doesn't support auto-sizing so I can align the header label and buttons around the textbox (top and bottom).
I came across the same problem trying to update Alaska HD.
I have everything in a centrally aligned grouplist and each control has it's own visible condition based on whether it's empty/visible or not so there's no gaps. Using a textbox destroys this as it can't auto-size. I also discovered !IsEmpty(Control.GetLabel(9)) doesn't work.
Thoughts?
