2014-01-09, 21:15
Hi
I've switched from LIRC to kernel event dev input, using ir_keytables stuff.
When I use the PVR plugin ( vnsi ), while watching a channel, I can't input multiple digit channels number. It only keeps the first keypress and then zap to this channel.
Using LIRC was working ok.
'remote sends keypresses'. is enabled.
Multiple numeric keys input seems to work on other places, I can type correctly any digit values while watching a movie to jump in time.
I use up to date Frodo & vnsi plugins:
Remote is Microsoft MCE RC6 type with Soundgraph Imon module.
Here is the log when I try to switch to channel number 41, but it switch to channel 4.
I've searched a lot on the net, but haven't found anybody having the same issue.
Quote: XBMC (12.3 Git:20131212-9ed3e58), Platform: Linux (Debian GNU/Linux testing (jessie), 3.9-1-686-pae i686)
Quote:20:07:37 T:3006638656 DEBUG: Keyboard: scancode: 53, sym: 0104, unicode: 0000, modifier: 0
[20:07:37 T:3006638656 DEBUG: OnKey: numpadfour (f074) pressed, action is Number4
20:07:37 T:3006638656 DEBUG: ------ Window Init (DialogNumeric.xml) ------
20:07:37 T:3006638656 DEBUG: Window DialogNumeric.xml was already loaded
20:07:37 T:3006638656 DEBUG: Alloc resources: 14.29m
20:07:37 T:3006638656 DEBUG: CAnnouncementManager - Announcement: OnInputRequested from xbmc
20:07:37 T:3006638656 DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputRequested
20:07:37 T:2515573568 DEBUG: CPullupCorrection: pattern lost on diff 60000.000000
20:07:37 T:3006638656 DEBUG: Keyboard: scancode: 57, sym: 0101, unicode: 0000, modifier: 0
20:07:37 T:3006638656 DEBUG: OnKey: numpadone (f071) pressed, trying keyboard action 61553
20:07:37 T:2618071872 DEBUG: CDVDPlayer::CheckContinuity - resync backward :2, prev:94183453630.000000, curr:94183053630.000000, diff:-400000.000000
20:07:38 T:3006638656 DEBUG: ------ Window Deinit (DialogNumeric.xml) ------
20:07:38 T:3006638656 DEBUG: CAnnouncementManager - Announcement: OnInputFinished from xbmc
20:07:38 T:3006638656 DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputFinished
20:07:38 T:3006638656 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
20:07:38 T:3006638656 DEBUG: Window DialogSeekBar.xml was already loaded
20:07:38 T:3006638656 DEBUG: Alloc resources: 0.02m
20:07:38 T:2507180864 DEBUG: CDVDPlayerAudio:: Discontinuity2 - was:94182035596.843338, should be:94182055596.843338, error:20000.000000
20:07:38 T:2507180864 DEBUG: CSoftAEStream::Flush
20:07:38 T:2507180864 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
20:07:38 T:2515573568 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
20:07:38 T:2618071872 DEBUG: CDVDPlayer::SetCaching - caching state 3
20:07:38 T:2618071872 DEBUG: PVRManager - PerformChannelSwitch - switching to channel 'FRANCE 4'
20:07:38 T:2618071872 DEBUG: PVR - SaveCurrentChannelSettings - no custom channel settings for channel 'FRANCE 2'
20:07:38 T:2618071872 DEBUG: AddOnLog: VDR VNSI Client: changing to channel 4
20:07:38 T:2939333440 DEBUG: CSoftAE::Run - Sink restart flagged
20:07:38 T:2939333440 INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_FLOAT, FL,FR, 48000hz
20:07:38 T:2939333440 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 5.1
20:07:38 T:2939333440 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 16384
20:07:38 T:2618071872 NOTICE: PVRManager - PerformChannelSwitch - switched to channel 'FRANCE 4'
