On first boot everything works great with frodo 12.3, after a unknown length of time. I have no audio and choppy playback. when i exit out of xbmc i can see my audio driver is disabled.
I have an onkyo receiver and an nvidia 7900gt. Connected with hdmi, running windows 7 64bit.
i have an error log
http://xbmclogs.com/show.php?id=108809
I have tried several different things i have read on the forums and not having any luck.
no realtek audio driver is installed. any thoughts on what i can do?
Weird, I can see (what I assume to be) the error in the log, but I can't see why it would just cut out after a length of time:
00:00:03 T:2532 INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
00:00:03 T:2532 INFO: CAESinkWASAPI::Initialize: Could not locate the device named "{B760053B-3758-4BE3-88BF-77BB6CC6FFA1}" in the list of WASAPI endpoint devices. Trying the default device...
00:00:03 T:2532 ERROR: CAESinkWASAPI::Initialize: Could not retrieve the default WASAPI audio endpoint. - (null)
00:00:03 T:2532 ERROR: CAESinkWASAPI::Initialize: WASAPI initialization failed.
Do you have the latest drivers for everything? Onkyo stuff sometimes doesn't handshake well with EDID, but it seems an EDID override shouldn't be necessary if everything's playing back fine already. I guess you could always just try with a nightly in portable mode and see if that works?
Edit: I suppose an obligatory nod to the
audio thread is in order.
Reading StartCodon's comments and the log snippet he/she extracted triggered a couple of thoughts. Specifically, the snippet would seem to indicate that the endpoint device disappeared. For example, maybe it was turned off or put to sleep.
Do you think it might be a power saving thing happening to your PC? I know that some laptops had issues with some PCI express link state power management setting screwing with things, from what I recall. You could create a custom power plan and use the advanced settings to ensure all the power saving stuff is off, and the PC is running at "full power".
If you do this, be careful when creating a new one if you copy from an existing. Even the High Performance built in power scheme has some manner of power saving settings enabled. Thus why I mention also editing via the advanced option link.
I have an NVidia GPU on my Atom powered HTPC connected to my AVR (see sig), and I had weird issues with loosing audio. Not quite the same as you, as I never lost it while playing. But it happened just around the time when I upgraded to new video drivers (which included new HDMI audio driver stuff). I when back to the previous driver and didn't have problems. I've upgraded to newer drivers since then and not noticed the same issues.
Might be worth a try to upgrade the video to a newer, stable, released driver.
Good luck.
I believe I found the exact solution to this problem last night, it's been plaguing me for a hell of a long time.
Mine is different, in that I get NO audio whatsoever if I turn my amp and television off, once I turn them back on, the HTPC with an nvidia card can not output audio anymore.
Here's your answer.
http://www.avsforum.com/t/1482693/workar...ff-then-on
(Long story short, you need to make a batch file on your desktop, which runs a very small program called "devcon" - it will disable and then re-enable your video card which will re-handshake the HDMI / HDCP stuff and fix the audio stream)
I hope this helps you because it helped me significantly, I was sick of rebooting my HTPC.
