Full Version: Cannot download/install AddOns
Hi All,
I have just installed XBMC 13 (Windows 7 x64) to have a play with, as I plan on building a HTPC later on in the year.
The install went fine. I ran the program, added my movies folder and then left it over night to get the relevant info. This all seems to have gone well.
Now I've decided to get some skins, which is where my problem arises. I chose Aeon Nox as the first skin, it got to 25% and then just stopped downloading. I tried again several times with the same error. I have tried several other skins now which won't download completely either, although some get more/less than 25%.
So I had a bit of a look around before I decided to make this post, and I found the following thread which I decided to try first to assist in making this post. The problem is that I can't even add the XBMC Log Uploader. It just says "Downloading 0%" and then flashes off and that is it.
Does anyone have any tips/pointers to where I might look to try and get this sorted ?
TIA
Rob.
Here is the debug log, if that helps any: http://pastebin.com/2nSHVDNk
Is XBMC actually able to access the internet?
(2014-01-11, 05:24)robcott Wrote: [ -> ]Here is the debug log, if that helps any: http://pastebin.com/2nSHVDNk
what server is closest to you?
http://mirrors.xbmc.org/list.html
just try to download .zip file from http://mirrors.xbmc.org/addons/frodo/scr...ownloader/ and see which server you are getting it from.
you are getting partial files it seems
Thanks for the replies.
I have just tried again within the last hour and it has worked as expected, so I'm guessing there may have been server issues when I was trying earlier.
