2014-01-11, 10:26
2014-01-13, 13:42
I have noticed the same thing. I have four installations of Frodo that were running on 12.2
Yatse is installed on three Android devices to control these XBMC installs, I use a MySQL database for a shared library setup. All was working well until I decided to upgrade all to 12.3 on Saturday night.
Firstly the Music library disappeared and I needed to rescan the music sources but more annoyingly Yatse does not work on any 12.3 installation.
I have had to resort to the official XBMC remote which is poor in comparison.
2014-01-13, 14:30
I can't comment for 12.3, however yatse works fine for me on Gotham. Try one of the development builds. I use linux PCs and raspberry pis for my media centre.
2014-01-13, 16:59
It's most likely the update has just messed with the XBMC share. Double check that XBMC is still allowing control using your share method (http?) & that the settings have not been changed (e.g. from port 80 to port 8080). Then try to initiate a new host with Yatse.
Failing that, get a Yatse debug log & submit a post with a link to the log in the Yatse support thread. Tolriq is usually very responsive.
2014-01-14, 10:17
Checked the remote control settings and ports. All looks correct but still can't get Yatse to work with Frodo 12.3
When I get time I'll log a bug report regarding Yatse.
2014-01-14, 22:26
My problem was that the XBMC device has changed IP address (allocated a new address by the router) and as a result Yatse couldn't connect.
Since the problem happened with the upgrade to 12.3 I mistakenly linked it to the new version.
Once I changed the IP address on Yatse all is working.
Thanks for the answers.
Avi
Avi
