2014-01-12, 04:47
Not sure what is going on, but I ripped some Bluray's I own using MakeMKV and DVDFab. Main movie, HD audio, and subtitles.
When playing these back in XBMC some of the files are getting tons of, what I guess I'd call, color banding.
The same files play without issue in VLC and other players.
Also, I've tested the files on multiple Windows PC's installed with XBMC and the same thing happens on each.
The two files that this is occurring on right now is WALLE and Ratatouille. Spider-Man 3 doesn't exhibit any of this behavior.
I've tried changing various settings (like deinterlacing which I had to switch to Off instead of Auto because it didn't seem to detect correctly with a Monsters, Inc DVD rip, yet another problem) but nothing changes.
Any idea what might be going on?
Video of Problem
Screenshots
MediaInfo
WALLE
Ratatouille
Spider-Man 3
Video of Problem
Screenshots
MediaInfo
WALLE
General
UniqueID/String : 241569860120519617021798917349333622025 (0xB5BCA9A875E8A0EDBC5A0A421DC15D09)
CompleteName : \Movies\WALL·E\WALL·E.mkv
Format : Matroska
Format_Version : Version 2
FileSize/String : 18.9 GiB
Duration/String : 1h 38mn
OverallBitRate_Mode/String : Variable
OverallBitRate/String : 27.6 Mbps
Movie : QUACK_D1.Title81
Encoded_Date : UTC 2014-01-10 03:42:04
Encoded_Application : DVDFab
Encoded_Library/String : libebml v0.7.8 + libmatroska v0.8.1
Video
ID/String : 1
Format : AVC
Format/Info : Advanced Video Codec
Format_Profile : [email protected]
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 4 frames
CodecID : V_MPEG4/ISO/AVC
BitRate_Mode/String : Constant
BitRate_Nominal/String : 30.5 Mbps
Width/String : 1 920 pixels
Height/String : 1 080 pixels
DisplayAspectRatio/String : 16:9
FrameRate_Mode/String : Constant
FrameRate/String : 23.976 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Bits-(Pixel*Frame) : 0.613
Default/String : Yes
Forced/String : No
colour_primaries : BT.709
transfer_characteristics : BT.709
matrix_coefficients : BT.709
Audio
ID/String : 2
Format : DTS
Format/Info : Digital Theater Systems
Format_Profile : MA / Core
Format_Settings_Mode : 16
Format_Settings_Endianness : Big
CodecID : A_DTS
BitRate/String : Unknown / 1 509 Kbps
Channel(s)/String : 6 channels
ChannelPositions : Front: L C R, Side: L R, LFE
SamplingRate/String : 48.0 KHz
BitDepth/String : 24 bits
Compression_Mode/String : Lossless / Lossy
Language/String : English
Forced/String : No
Text
ID/String : 3
Format : PGS
CodecID : S_HDMV/PGS
CodecID/Info : The same subtitle format used on BDs/HD-DVDs
Forced/String : No
Ratatouille
General
Unique ID : 250239101457312280879621406159070686590 (0xBC424C418E92D0149386F09ADC01ED7E)
Complete name : \Movies\Ratatouille\Ratatouille.mkv
Format : Matroska
Format version : Version 2
File size : 24.0 GiB
Duration : 1h 50mn
Overall bit rate mode : Variable
Overall bit rate : 31.0 Mbps
Movie name : RATATOUILLE.Title1(1)
Encoded date : UTC 2014-01-10 07:33:33
Writing application : DVDFab
Writing library : libebml v0.7.8 + libmatroska v0.8.1
Video
Format : AVC
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=12
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 50mn
Bit rate mode : Variable
Maximum bit rate : 34.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : PCM
Codec ID : A_PCM/INT/LIT
Duration : 1h 50mn
Bit rate mode : Constant
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 50mn
Bit rate : 640 Kbps
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 506 MiB (2%)
Language : English
Default : No
Forced : No
Text
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Default : Yes
Forced : No
Spider-Man 3
General
Unique ID : 197757840171133820914777492531311651768 (0x94C6C64CFDC2379E106D8536D8E1ABB8)
Complete name : \Spider-Man 3\Spider-Man 3.mkv
Format : Matroska
File size : 34.2 GiB
Duration : 2h 19mn
Overall bit rate : 35.2 Mbps
Movie name : Spider-Man™ 3 Feature Disc
Encoded date : UTC 2014-01-12 00:33:20
Writing application : MakeMKV v1.8.7 win(x64-release)
Writing library : libmakemkv v1.8.7 (1.3.0/1.4.1) win(x64-release)
Video
Format : AVC
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=10
Duration : 2h 19mn
Color space : YUV
Bit depth : 8 bits
Language : English
Default : No
Forced : No
Audio #1
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 2h 19mn
Maximum bit rate : 5 220 Kbps
Bit depth : 24 bits
Compression mode : Lossless
Title : 5.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 2h 19mn
Bit rate : 640 Kbps
Bit depth : 16 bits
Stream size : 637 MiB (2%)
Title : 3/2+1
Language : English
Default : No
Forced : No
Audio #3
Format : PCM
Codec ID : 00001000-0000-0100-8000-00AA00389B71
Duration : 2h 19mn
Bit rate : 4 608 Kbps
Bit depth : 16 bits
Stream size : 4.48 GiB (13%)
Title : 3/2+1
Language : English
Default : No
Forced : No
Audio #4
Format : AC-3
Format profile : Dolby Digital
Codec ID : A_AC3
Duration : 2h 19mn
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Bit depth : 16 bits
Stream size : 191 MiB (1%)
Title : 2/0
Language : English
Default : No
Forced : No
Audio #5
Format : AC-3
Codec ID : A_AC3
Duration : 2h 19mn
Bit rate : 192 Kbps
Bit depth : 16 bits
Title : 2/0
Language : English
Default : No
Forced : No
Text #1
Format : PGS
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Language : English
Default : No
Forced : No
