Full Version: No Pause during live tv [SOLVED]
I just migrated from mythtv to tvheadend. Its very easy to setup. I'm using unstable build, 3.9.355 with Xbmc frodo 12.3. The add-on version is 1.6.9.
While watching livetv i'm unable to pause or move forward/backward. I understand timeshifting is supported so I guess something is wrong in my setup?
thank you.
see if timeshift is enabled - configuration>recording>timeshift
edit: i use an older version of tvheadend so maybe in a different location
So simple Smile
thank you very much.
is it working for you properly? for me it stops working after only 2-3 Minutes (Pause - Wait 5 Min - watch 2-3Min - Video stops)
(2014-01-16, 16:09)tom1502 Wrote: [ -> ]is it working for you properly? for me it stops working after only 2-3 Minutes (Pause - Wait 5 Min - watch 2-3Min - Video stops)
I'm using 3.9.355 (unstable repository). Your bug doesn't replicate here. I paused for more than 5min. after that playback resumed instantly for more than 3 minutes.
