Full Version: Version 2.5
after 1,5 months and about 200 commits we are proud to announce
tinyMediaManger v2.5
Changes:
feature: completely reworked the TV show panel (including a new panel for seasons - http://www.tinymediamanager.org/index.ph...w-section/ )
feature: completely reworked the (movie) filter panel and added a filter panel for TV shows (see http://www.tinymediamanager.org/index.ph...er_panels/ )
feature: added movie filters: datasource, missing metadata, missing artwork, missing subtitles, new movies
feature: added TV show filters: datasource, cast member, missing metadata, missing artwork, missing subtitles, new episodes
feature: added possibility to hide several columns in the movie table
feature: experimental support for AniDB scraper
feature: added fanart.tv for TV shows
feature: added imdb top 250
feature: added producers
feature: added an ASCII cleaner for the renamer
feature: added "bad words" to the movie importer
feature: possibility to get the runtime from media files rather than scraper
feature: added some settings for the TV show renamer
feature/fix: reworked tagging of TV shows and episodes
fix: many enhancements to the "update datasources" and database engine -> tmm is much faster now with large databases
fix: some fixes and preventions to the "update datasources" engine
fix: many memory optimizations (tmm now uses less memory)
fix: when renaming an actor, the actor thumb also gets renamed
fix: several issues/problems with the renamer
fix: artwork naming for DVD/BR images
fix: adapted scaling factor of the tmm window - now it should fit on lower screens nicely
fix: crash at startup with invalid locales
fix: crash when searching for a movie set is fixed with themoviedbapi 3.9
fix: NFO parsing of xbmc-youtube plugin urls
fix: externalized some more string (better translations)
fix: several fixes to the TV show renamer
translations: added spain (thx to roliverosc), italian (thx to peppe_sr), korean (thx to piodio), norwegian (thx to roandr); completed fr (thx to nerve)
thx to all who helped us for this version!
Thx!
Very great job Big Grin
Wow very nice job! I love the speed of the update data sources now.
Good job! Could not update my old installation (2.4.7 last), showed an error after the update (Entity is not found: org.tinymediamanager.core.movie.Movie#1032).
Running Windows 7 x64 Java 7u45
I deleted the tinymediamanager folder in %appdata% and reinstalled. So far it's working good Smile
hmm.. interesting.
We did many tests with old installations.... and it worked.
If it happens again (to someone) please send us the logfiles from the /logs/ directory. (and maybe the DB fille to reproduce)
Reinstallation of TMM is not needed, just delete the TMM.ODB database....
14.01.2014 - version 2.5.1
x fixed a problem where mediainfo could not be loaded
x fixed a database loading problem
