2014-01-13, 18:47
I've been running XBMC now for a year or so and I'm delighted with it. My wife and kids are getting far more use from it than I could have imagined. So a big +1 for XBMC....... The machine is a Silverstone GD04 case with a 64GB Crucial SSD, AMD A6 5400K, F2A85-M LE, 4GB RAM etc. Nice little HTPC....
Up to now I've been feeding this from a HP N40L Microserver running Windows 7 with FlexRAID parity/pool of 4 x 2TB drives (5.6TB usable). Also have a couple of smaller drives in there for the OS and downloads. Now though I'm running out of space so I need to upgrade.
The cheap option might be to replace the 4 x 2TB drives with 4 x 3TB drives in the HP Microserver but that's not giving me a huge amount of extra space or any further future expansion. With that in mind I'm thinking of a new build.
What hardware would you recommend for a 24/7 fileserver running Windows 8.1? I'm thinking I might give up on FlexRAID and use the Windows Storage Spaces.
Case wise I'm thinking of the Silverstone GD08: 8 x 3.5" drives, 2 x 2.5" drives and 2 x 5.25" bays. So if I put an optical drive in, that leaves me with space for 9 x 3.5" drives plus a 2.5" SSD for the OS. I'll then put a spare 2.5" drive in there and use for something or other. Using my current 4 x 2TB drives and purchasing a further 1 x 3TB drive it's giving me 11TB of storage (not including any parity or mirroring) and leaving 3 bays unused (for a further potential of 12TB should 4TB drives become affordable). The case is more or less standard media equipment width so I'll locate it on my media rack under the stairs. I may match this case with a Silverstone Strider PSU.
So my main question is what other hardware to put inside the case. I think I'll want a low power CPU (thinking an i3 3220T), 4GB RAM, motherboard and SATA cards (assuming I can't get a board with 11 or 12 SATA ports).
Essentially this box will be used to store all my media and perhaps run a Bit Torrent VM. If I put a Bluray drive in I might use this machine to rip movies instead of my work PC.
Any hardware suggestions welcome.......
