2016-03-15, 03:59
2016-04-06, 03:46
I am on kodi twit plug 2.1.3
Raspberry pi 3
And twit live is not showing up.
Any help would be appreciated..
Raspberry pi 3
2016-04-06, 04:23
(2016-04-06, 03:46)ktg69 Wrote: [ -> ]I am on kodi twit plug 2.1.3
Raspberry pi 3
Try going into the plugin settings and changing the stream used for live.
2016-04-08, 23:19
I tried all the different live options and still not live link shows in the Twit app.
I also tried rolling back, uninstalling. Nothing seems to work.
I use the Amber skin but I have also tried going back to confluence with no avail.
No errors but I can not see the Live option in the list.
2016-04-09, 20:35
(2016-04-08, 23:19)ktg69 Wrote: [ -> ]I tried all the different live options and still not live link shows in the Twit app.
It is possible that you have "Hide Watched" enabled on your skin.
2016-04-09, 22:57
That was it! Thank you very much.
2016-05-08, 05:08
Addon not working
Error details below...
PHP Code:
23:06:33 T:11024 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: expected string or buffer
File "C:\Users\quick\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py", line 444, in <module>
display_main()
File "C:\Users\quick\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py", line 100, in display_main
display_shows('active')
File "C:\Users\quick\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py", line 78, in display_shows
shows = cache.cacheFunction(shows_cache)
File "C:\Users\quick\AppData\Roaming\Kodi\addons\script.common.plugin.cache\lib\StorageServer.py", line 570, in cacheFunction
ret_val = funct(*args)
File "C:\Users\quick\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py", line 69, in shows_cache
'active': parse_shows_to_list(base_url + '/shows?shows_active=1'),
File "C:\Users\quick\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py", line 59, in parse_shows_to_list
convertEntities=BeautifulSoup.HTML_ENTITIES)
File "C:\Users\quick\AppData\Roaming\Kodi\addons\script.module.beautifulsoup\lib\BeautifulSoup.py", line 1522, in __init__
BeautifulStoneSoup.__init__(self, *args, **kwargs)
File "C:\Users\quick\AppData\Roaming\Kodi\addons\script.module.beautifulsoup\lib\BeautifulSoup.py", line 1147, in __init__
self._feed(isHTML=isHTML)
File "C:\Users\quick\AppData\Roaming\Kodi\addons\script.module.beautifulsoup\lib\BeautifulSoup.py", line 1171, in _feed
smartQuotesTo=self.smartQuotesTo, isHTML=isHTML)
File "C:\Users\quick\AppData\Roaming\Kodi\addons\script.module.beautifulsoup\lib\BeautifulSoup.py", line 1773, in __init__
self._detectEncoding(markup, isHTML)
File "C:\Users\quick\AppData\Roaming\Kodi\addons\script.module.beautifulsoup\lib\BeautifulSoup.py", line 1918, in _detectEncoding
'^<\?.*encoding=[\'"](.*?)[\'"].*\?>').match(xml_data)
TypeError: expected string or buffer
23:06:33 T:9476 ERROR: Previous line repeats 1 times.
23:06:33 T:9476 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.twit/
23:06:33 T:9476 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.twit/) failed
23:06:34 T:9476 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.twit/
23:06:34 T:9476 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.twit/) failed
2016-05-08, 14:48
Yep Twit app is dead here too
2016-05-08, 18:42
My TWiT add-on is the same! :-(
2016-05-08, 18:53
Here are my logs in Debug Mode:
PHP Code:
17:47:32 T:12744 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
17:47:32 T:12744 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.twit/?content_type=video)
17:47:32 T:12744 DEBUG: ParentPath = [addons://sources/video]
17:47:32 T:15916 DEBUG: Thread JobWorker start, auto delete: true
17:47:32 T:15916 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin TWiT('plugin://plugin.video.twit/','17','?content_type=video')
17:47:32 T:15916 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the TWiT (id=22) plugin...
17:47:32 T:16036 DEBUG: Thread LanguageInvoker start, auto delete: false
17:47:32 T:16036 INFO: initializing python engine.
17:47:32 T:16036 DEBUG: CPythonInvoker(22, C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py): start processing
17:47:32 T:16036 DEBUG: -->Python Interpreter Initialized<--
17:47:32 T:16036 DEBUG: CPythonInvoker(22, C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py): the source file to load is "C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py"
17:47:32 T:16036 DEBUG: CPythonInvoker(22, C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py): setting the Python path to C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit;C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\script.common.plugin.cache\lib;C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\script.module.beautifulsoup\lib;C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\script.module.feedparser\lib;C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\script.module.parsedom\lib;C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\script.module.simple.downloader\lib;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
17:47:32 T:16036 DEBUG: CPythonInvoker(22, C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py): entering source directory C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit
17:47:32 T:16036 DEBUG: CPythonInvoker(22, C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py): instantiating addon using automatically obtained id of "plugin.video.twit" dependent on version 2.1.0 of the xbmc.python api
17:47:33 T:12744 DEBUG: ------ Window Init (DialogBusy.xml) ------
17:47:33 T:16036 DEBUG: [plugin.video.twit-2.1.3]: Get root directory
17:47:33 T:16036 DEBUG: LocalizeStrings: no strings.po file exist at C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit\resources\language\English, fallback to strings.xml
17:47:34 T:16036 DEBUG: [plugin.video.twit-2.1.3]: We failed to open "https://twit.tv/shows?shows_active=1".
17:47:34 T:16036 DEBUG: [plugin.video.twit-2.1.3]: We failed to reach a server.
17:47:34 T:16036 DEBUG: [plugin.video.twit-2.1.3]: Reason: [Errno 1] _ssl.c:510: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure
17:47:34 T:16036 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
File "C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py", line 444, in <module>
display_main()
File "C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py", line 100, in display_main
File "C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py", line 78, in display_shows
File "C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\script.common.plugin.cache\lib\StorageServer.py", line 570, in cacheFunction
File "C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py", line 69, in shows_cache
File "C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\plugin.video.twit\default.py", line 59, in parse_shows_to_list
File "C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\script.module.beautifulsoup\lib\BeautifulSoup.py", line 1522, in __init__
File "C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\script.module.beautifulsoup\lib\BeautifulSoup.py", line 1147, in __init__
File "C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\script.module.beautifulsoup\lib\BeautifulSoup.py", line 1171, in _feed
File "C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\script.module.beautifulsoup\lib\BeautifulSoup.py", line 1773, in __init__
File "C:\Users\Armando Ruas\AppData\Roaming\Kodi\addons\script.module.beautifulsoup\lib\BeautifulSoup.py", line 1918, in _detectEncoding
17:47:34 T:12744 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
17:47:34 T:5864 INFO: CActiveAESink::OpenSink - initialize sink
17:47:34 T:5864 DEBUG: CActiveAESink::OpenSink - trying to open device DIRECTSOUND:default
17:47:34 T:16036 INFO: Python script stopped
17:47:34 T:16036 DEBUG: Thread LanguageInvoker 16036 terminating
17:47:34 T:5864 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 0E8508CA
17:47:34 T:5864 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
17:47:34 T:5864 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
17:47:34 T:5864 DEBUG: Audio Device : Speakers (USB Multi-Channel Audio Device)
17:47:34 T:5864 DEBUG: Sample Rate : 44100
17:47:34 T:5864 DEBUG: Sample Format : AE_FMT_FLOAT
17:47:34 T:5864 DEBUG: Bits Per Sample : 32
17:47:34 T:5864 DEBUG: Valid Bits/Samp : 32
17:47:34 T:5864 DEBUG: Channel Count : 6
17:47:34 T:5864 DEBUG: Block Align : 24
17:47:34 T:5864 DEBUG: Avg. Bytes Sec : 1058400
17:47:34 T:5864 DEBUG: Samples/Block : 32
17:47:34 T:5864 DEBUG: Format cBSize : 22
17:47:34 T:5864 DEBUG: Channel Layout : FL,FR,FC,LFE,SL,SR
17:47:34 T:5864 DEBUG: Channel Mask : 1551
17:47:34 T:5864 DEBUG: Frames : 661
17:47:34 T:5864 DEBUG: Frame Samples : 3966
17:47:34 T:5864 DEBUG: Frame Size : 24
17:47:34 T:5864 DEBUG: CActiveAESink::OpenSink - DIRECTSOUND Initialized:
17:47:34 T:5864 DEBUG: Output Device : default
17:47:34 T:5864 DEBUG: Channel Layout: FL,FR,FC,LFE,SL,SR
17:47:34 T:15916 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - plugin exited prematurely - terminating
17:47:34 T:12744 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.twit/?content_type=video
17:47:34 T:12744 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.twit/?content_type=video) failed
17:47:34 T:12744 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/video)
17:47:34 T:12744 DEBUG: ParentPath = [addons://sources/]
2016-05-09, 14:25
Hi guys,
If you look at the logs you'll see this if system debug is on -
TWiT uses https and the handshake is failing. From my googling this seems to be a python =< 2.7 bug with SSL. I don't know of any workaround we can use
This error has happened a few times in the past but only for a day or two.
Sorry for the lack of better news. If anyone has any ideas, please share.
2016-05-09, 14:27
Kodi v17 uses python 2.7.11 for all versions (not sure if that helps)
2016-05-09, 14:34
From what I've read it's fixed in python 3.0
2016-05-10, 13:33
As a crutch, for my personal use, I created simple playlist, for Playlist Loader, with latest TWiT.tv shows in SD resolution:
http://pastebin.com/raw/Fgnsq5DU
Playlist Loader video addon is from this repository:
https://github.com/cubicle-vdo/xbmc-isra...-1.0.4.zip
I will update playlist once a day - if someone else wants to use it, go for it.
Playlist will self destruct when twit.tv addon awakes from a coma
2016-05-11, 20:21
I wonder if it would be possible to use a simple http->https proxy, so that the API can still make its http requests, but those get transparently translated to https by the proxy.
