Was wondering if there is a source in the addon section of XBMC that I can add so I can go to it when I want to "add from zip". Another known forum uses Fusion as a source for its addons. What can I use for the XBMC.org addons? (if there is anything like Fusion)
In theory you could do this, since it's just an HTTP directory, but XBMC has all of those add-ons listed automatically in the "XBMC.org" add-on repository.
http://mirrors.xbmc.org/addons/frodo/ is where all the add-ons get downloaded from, but it's the exact same add-ons you get from the built-in method.
Is there any particular reason you want to access them that way?
Not really. I just never thought all 400 to 500+ addons were included in the XBMC install. It that is so then it's even better.
Thanks for your reply.
Not included in the install, they are accessible/available via XBMC repo, so once you select one to install from the list it downloads it and installs it. Included in install is ridiculously big install...
I guess that is what I meant that the 400 to 500+ are included in the repo....therefore they are in the XBMC install (ready to be install as required).
Yes, idk how many there are in official repo, but yes.
