2014-01-14, 22:30
I'm starting to run out of things to try to get this working. For some reason XBMC only outputs 2 channels to the Pioneer AVR which is then connected to the TV, all via HDMI
aplay -L
amixer output
Playback channels = mono??
If i play a file that has DTS (6 channel sound) xmbc.log reports.
A couple of interesting lines. "sink incompatible" and "keeping old sink with" FL and FR
On startup xbmc detects the AVR with 7.1 support.
Startup Alsa devices dectected
The HTPC is connected via HDMI to "PIO VSX-826 on HDMI #2" device 3 in the list which has 7.1 capabilities but is only connected to 5.1 speaker setup.
Below is the audio information from the test file i was using to test with.
mediainfo audio settings test file.
I'm a little bit lost as to where to look now. I have searched for asound.conf files no user or system wide files exist.
Kernel is Ubuntu 3.11.0 x64 with this patch ALSA HDA - HDMI
I also checked out the kernel source for 3.12.7 and confirmed that the above patch is now included in the source...
aplay -L
amixer output
01:30:04 T:140186193409792 DEBUG: CSoftAE::Run - Sink restart flagged
01:30:04 T:140186193409792 INFO: CSoftAE::InternalOpenSink - RAW passthrough enabled
01:30:04 T:140186193409792 INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
01:30:04 T:140186461607808 DEBUG: LIRC: Update - NEW at 127402:000000000000000b 00 SELECT_UP XboxDVDDongle (SELECT_UP)
01:30:04 T:140184528066304 WARNING: CRenderManager::Configure - timeout waiting for previous frame
01:30:04 T:140184528066304 NOTICE: Display resolution ADJUST : HDMI3: 1920x1080 @ 23.98Hz (21) (weight: 0.000)
01:30:04 T:140186461607808 INFO: XRANDR: /usr/lib/xbmc/xbmc-xrandr --output HDMI3 --mode 0x51
01:30:04 T:140186193409792 INFO: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=MID,DEV=2"
01:30:04 T:140186193409792 INFO: CAESinkALSA::Initialize - Opened device "hdmi:CARD=MID,DEV=2,AES0=0x06,AES1=0x82,AES2=0x0$
01:30:04 T:140186193409792 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2400, bufferSize 9600
01:30:04 T:140186193409792 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2400, bufferSize 9600
01:30:04 T:140186193409792 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 200 ms
01:30:04 T:140186193409792 DEBUG: CSoftAE::InternalOpenSink - ALSA Initialized:
01:30:04 T:140186193409792 DEBUG: Output Device : HDA Intel MID
01:30:04 T:140186193409792 DEBUG: Sample Rate : 48000
01:30:04 T:140186193409792 DEBUG: Sample Format : AE_FMT_S16NE
01:30:04 T:140186193409792 DEBUG: Channel Count : 2
01:30:04 T:140186193409792 DEBUG: Channel Layout: FL,FR
01:30:04 T:140186193409792 DEBUG: Frames : 2400
01:30:04 T:140186193409792 DEBUG: Frame Samples : 4800
01:30:04 T:140186193409792 DEBUG: Frame Size : 4
01:30:04 T:140186193409792 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 9600
01:30:04 T:140184167376640 DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
01:30:04 T:140184167376640 DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:209210.110000, should be:10057.784667, error:-1991$
01:30:04 T:140184125413120 DEBUG: CDVDPlayer::HandleMessages - player started 1
01:30:04 T:140186193409792 INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_DTS, FL,FR, 48000hz
