2014-01-15, 14:46
2014-01-15, 15:44
If I remember correctly Frodo requires OSX 10.6 as a minimum.
http://wiki.xbmc.org/index.php?title=XBM...quirements
2014-01-15, 18:26
I could swear 12.3 would never run on osx 10.5 ... are you sure its not osx 10.6?
2014-01-16, 12:17
Sorry it's 10.7.5
2014-01-16, 16:04
(2014-01-16, 12:17)sjobbels Wrote: [ -> ]Sorry it's 10.7.5
How are you shutting down the app? I've noticed this behavior when using the shutdown button on the home menu but I can avoid it by pushing "s" on my keyboard and select "Exit". Not sure if this has been fixed in Gotham or not.
2014-01-22, 15:07
(2014-01-16, 16:04)wgstarks Wrote: [ -> ](2014-01-16, 12:17)sjobbels Wrote: [ -> ]Sorry it's 10.7.5
Yes via the home menu....
2014-01-22, 16:58
From what I've read Frodo will not be developed further, so I don't think this behavior will get fixed in this version of xbmc. You might want to check out Gotham and see if the problem persists or shutdown the app using the popup menu.
2014-01-25, 22:49
Gotham doesn't open. I think because of myphp library (advancesettings.xml)
2014-01-26, 11:49
Debug log. It could be one of the add ons that is not exiting gracefully. Try moving all the extra crap temporarily away from the add ons directory and see if it helps.
2014-01-26, 13:37
I've managed it! Deleted some addons and deleted an old database in the mysql table.
