I am using this Skin and I am quite happy with it.
My Question is: Does this Skin Support animated Fanart (Posters, keyart and so on) ?
(2019-07-05, 15:36)themediaman Wrote: [ -> ]Is there a quick way to configure the home menu to resemble the previous build......
Do I really need to configure it all from scratch again....?
Not if you already had it installed, the menus config files should be there and just inherited. That worked for me however I'm not sure I may have done a backup of them then did install then restored my config files.
I installed kodi 18 with aeon silvo, but i get the menus structure not right
i have a menu like MOVIES, SERIES, KIDZONE. all three should point to a specific directory .
when i select SERIES , i get a list a script.skinshortcuts list. see attach, when i select that i get the series what i need. but what im doing wrong. it should be direct going to the series
I have been using Aeon Nox 5:Redux for many years now and love it. I have yet to try out Silvo, as I don't want to have to re-create all my menus.
But I've noticed recently that in Aeon Nox 5: Redux, when I pause a TV Show or Movie, and I have the "Netflix style" pause screen active in the skin settings, it shows a double show logo. Did anyone else have this problem?
I've been trying to get skin.aeon.nox.5 fully working with python3. After about a gazillion small changes to the skin and the cascading waterfall of dependencies I think I've got most things working (probably not), but I'm stuck now. Whenever I try to create a smart shortcut, I wind up with a list that consists of ".." and nothing else. Any ideas why that is? Or better yet, anyone have a fully python3'ed script.skinshortcuts?
Hopefully this is a simple/quick question to answer :
How do I set the default background for a menu item ?(e.g. system, apps, search, power) ?
I don't mind if it's 1 background for each item, or if each item has their own default background
I'm running Kodi 18.5 on a Windows 10 laptop, with the Aeon Nox Silvo skin
Is it possible to use openinfo as default info view or if click info on remote it opens on openinfo.
i'm trying to install this skin on Leila 18.7,but I get this error
how can i solve? thank you
the dependency on xmbc.gui version 5.12.0 could not be satisfied.
(2020-07-06, 12:04)rossomike1966 Wrote: [ -> ]i'm trying to install this skin on Leila 18.7,but I get this error
Why are you trying to install via zip file? Your zip file contains the wrong version of the skin.
Install directly from the Kodi repository under
Settings>Addons>Look and Feel>Skin or via
Settings>Interface>Skin>Skin>Get more
(2020-07-06, 12:55)Karellen Wrote: [ -> ] (2020-07-06, 12:04)rossomike1966 Wrote: [ -> ]i'm trying to install this skin on Leila 18.7,but I get this error
Install directly from the Kodi repository under Settings>Addons>Look and Feel>Skin or via Settings>Interface>Skin>Skin>Get more
from
Settings>Interface>Skin>Skin>Get more i see only Aeon MQ8 and Aeon Tajo and others skin..but not Nox 5
Oh, so sorry I did not read which thread you posted in.
Nox 5 is unsupported and I don't know if there is a Leia version available. Try aeon Nox Silvio which is the replacement.
(2020-07-06, 13:26)rossomike1966 Wrote: [ -> ] (2020-07-06, 12:55)Karellen Wrote: [ -> ] (2020-07-06, 12:04)rossomike1966 Wrote: [ -> ]i'm trying to install this skin on Leila 18.7,but I get this error
from Settings>Interface>Skin>Skin>Get more i see only Aeon MQ8 and Aeon Tajo and others skin..but not Nox 5
If you want this skin, i can help you with it, i have it on my Dropbox.
(2020-08-17, 18:57)Paul Shield Wrote: [ -> ] (2020-07-06, 13:26)rossomike1966 Wrote: [ -> ] (2020-07-06, 12:55)Karellen Wrote: [ -> ]Why are you trying to install via zip file? Your zip file contains the wrong version of the skin.
thank you very much..i'd like to get it!!
can you send me in PM link please?
