2014-03-19, 11:41
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264
2014-03-19, 12:54
Hi BigNod
Thank you for this skin, I loved v4 and I like v5 aswell.
I have a wish for the future and a question about the current version.
Wish:
Is it possible to hide the top bar in movies, tv-show view, it was possible in v4, but maybe a feature comming later on.
Question:
When activation the "recent movies" or "recent episodes" widgets the widgets just load and load, I have re scanned the video library using the left menu in each category but it does not help, anything I'm missing?
Thanks again for your work.
Wish:
Question:
2014-03-19, 13:03
I took the link down. I'm not at a pc right now. Will upload a new link later.
2014-03-19, 13:08
Hi BigNoid,
Thanks a lot for v5, it's gorgeous and super fast.
2 quick questions :
- do you plan on making the infowall view available for episodes ? would make sense imho
- You have set timers for the infopanel in showcase view : will you include a way to trigger it manually (like pressing 2 times 'down' for example) ?
Thanks again.
2 quick questions :
Thanks again.
2014-03-19, 13:25
(2014-03-19, 00:24)Vaikin Wrote: [ -> ]Thanks for your reply,(2014-03-18, 23:23)NeroBoron Wrote: [ -> ]hey,There is for existing media, not sure about pvr stuff. Shows poster, name season, episode, date and progress time.
i really like the new theme looks cleaner.
Some points:
There is no now playing on home screen, when watching live tv.
Please re-add an episode view for TV shows.
Options to configure a view type like in last release.
Btw the backgrounds of 4.0 were awesome! I just extracted them and use them again
Looking forward to new versions, thanks for this skin
It's been said a bunch of times that episode view will not come back.
Options = lots of code = slower skin. BN is trying to keep it as simple as possible
existing media like movies, tv shows and music is fine. Just not live tv would expect the title of channel and maybe some information from epg in the now playing information of my homescreen.
Noooo hopefully another view then that fits to tv episodes
Hummm okay, don't bother at all, were only some small changes that i used, like bigger posters and the information within a tag line. I'm fine with a "keep it simple & clean" principle
2014-03-19, 20:11
(2014-03-19, 07:32)devilshura Wrote: [ -> ]Are there any option for logo in music visualization or use local artist images? Artist slideshow only work for extrafanart. I have some Artist folder to display all my music artist image&logo. That is something i don't want to miss.I havent looked at extra fanart and logos for music at all. I'll keep that in mind for future releases.
(2014-03-19, 09:54)Warner306 Wrote: [ -> ]I thought about redundancy, but i felt consistency was more important. When browsing the library my eye is on the title and not the flags, so in that case its easy to spot 3d content. Keep in mind that a lot of users dont enable the infopanel at all, so for them unwatched count mucht be handy. In any case the its a feature that can be turned off.(2014-03-19, 01:13)BigNoid Wrote: [ -> ]@Warner306: That option was already obsolete in Nox 4 when re-ordering of main menu items was introduced. I'm not sure about the info instead of genre label. If I can make a good settings description I might put it in the advanced settings section, but not sure yet. Playlist fanart can be added, will see how much code it is too add.
The option is not obsolete. It overrides the tendency of the skin to ignore custom home items in favor of standard sections (Video, TV Shows, etc.). That's why, no matter what order items are placed, my TV Shows section is always front-and-center when the program boots. Version 4 is no different. Changes the Custom Startup Focus position is the only way to override this.
I like the changes but noticed some redundant information in some views with the new flags. Perhaps the flags could be removed in these views?
Most content is HD these days. So I see no need to indicate the program is HD when the resolution is 720 or 1080.
The unwatched indicator doesn't fit the showcase view at all.
Also, the widgets on the home screen are much improved with the white text, but you missed the Now Playing widget; it is still difficult to read. Some extra glow around the text would make it even better.
Movie fanart is still displayed throughout the background of the music section, as well.
Theres no shadwo behind the now playing text, maybe thats why its harder to read. I'll see if its needed for that.
(2014-03-19, 12:54)pomah Wrote: [ -> ]Hi BigNodThe topbar is an integral part of the skin with info that I have no place for to display otherwise, so that wont be configurable. Its an include throughout the windows, so with a little search and replace thats an easy mod
Wish:
Question:
I got two major issues with the manual setting for infopanel:
- Its a navigational nightmare; so in one view pressing up brings out the media menu and then all of a sudden in showcase it reveals an infopanel. I rather keep navigating consistent. Not to mention that you'd expect that clicking when its highlighted should play the media (which can be done, but it would play the media in files mode).
- Its an afwul lot of code to add for a single function that imo only a small percentage of users actually use.
I only integrated the time out since it had very small impact on the amount of code needed.
(2014-03-19, 13:08)Sabish Wrote: [ -> ]Hi BigNoid,- Yeah InfoWall for episodes will be added.
2 quick questions :
Thanks again.
- See above explanation
(2014-03-19, 13:25)NeroBoron Wrote: [ -> ]Now playing for LiveTV is something I havent looked at yet, will keep that in mind for future releases.(2014-03-19, 00:24)Vaikin Wrote: [ -> ]Thanks for your reply,(2014-03-18, 23:23)NeroBoron Wrote: [ -> ]hey,There is for existing media, not sure about pvr stuff. Shows poster, name season, episode, date and progress time.
Some points:
2014-03-19, 20:45
Hi BigNoid,
just a short question - any plans for a white theme? Besides - excellent work so far! Thanks a lot.
Cheers,
h3ll
Cheers,
h3ll
2014-03-19, 23:13
When starting the skin for the first time, you should turn off many of the features by default. Having unwatched indicators and unwatched episode flags everywhere in all views make the skin look very busy. When switching between skins, the unwatched star is reactivated every time, even if you have previously turned it off.
Just my two cents...Having so many flags might turn-off some users when your intent is to make it look clean and modern. I have gone back and forth between version 4 and 5 and find them very similar at this stage. I have nicknamed this version Aeon Nox Bold (due to its larger text and simplified design) or Aeon Nox Light (due to its streamlined code).
2014-03-19, 23:35
Hi BigNoid,
So far so good. Only a few things I'd like to see added... Would like to see the "Glass Effect" for the home screen menu return, and the ability to make the main menu item text a bit dimmer, the bright white text is a bit TOO bright for me. This skin could also do with different default background images for each Main Menu Item IMHO. Having "Gravity" as the default for every screen is a bit too minimalist for me, but hey-ho. If I've missed anything in terms of options, then please point me in the right direction. Finally, for me, focus when playing music is to be on/with the Visualizer. Not the add-on info/artwork/clutter being visible all the time. MQ5 does this, and it's annoying not being able to have it dissappear after a set time. MQ5 does however have playback icons on the home screen, which Nox has lacked ever since i've used it. A consideration perhaps?
Nox is My favourite in the "Blue" corner, MQ5 in the "Red" corner.
To the Poster who said "Most Video Content is HD Nowadays", this is most certainly NOT True. What is true is that most content is AVAILABLE in HD form these days. That doesn't nessecarily mean that EVERY user has the desire to buy/store HD content across the board for their media center. What works for YOU, may not nessecarily work for me.
2014-03-19, 23:42
Instead of the current list of add-ons that stays the same, could rearranging the widgets on videos, music, etc...to always randomize items on startup, be possible, BigNoid ?
2014-03-19, 23:57
(2014-03-19, 23:13)Warner306 Wrote: [ -> ]When starting the skin for the first time, you should turn off many of the features by default. Having unwatched indicators and unwatched episode flags everywhere in all views make the skin look very busy. When switching between skins, the unwatched star is reactivated every time, even if you have previously turned it off.
Unwatched episodes count are off by default in beta3, just not in the test version you tried. Unwatched indicators can return when changing skins, a restart should fix that. Its not a everyday scenario for 99% of the users to change skins, so thats acceptable to me.
(2014-03-19, 20:45)h3llsp4wn Wrote: [ -> ]Hi BigNoid,I wont make a white theme...
Cheers,
h3ll
(2014-03-19, 23:35)gibxxi Wrote: [ -> ]Hi BigNoid,Why should I go to the trouble making default images for every menu item? Everybody can do that themselfs
(2014-03-19, 23:42)Riksa Wrote: [ -> ]Instead of the current list of add-ons that stays the same, could rearranging the widgets on videos, music, etc...to always randomize items on startup, be possible, BigNoid ?
Not possible with current xbmc code.
2014-03-20, 00:30
Getting the following exception with beta 3 and the latest script.skinshortcuts:
23:27:55 T:5632 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named unidecode
File "D:\XBMC\portable_data\addons\script.skinshortcuts\default.py", line 33, in <module>
import xmlfunctions
File "D:\XBMC\portable_data\addons\script.skinshortcuts\resources\lib\xmlfunctions.py", line 14, in <module>
import datafunctions
File "D:\XBMC\portable_data\addons\script.skinshortcuts\resources\lib\datafunctions.py", line 10, in <module>
from unidecode import unidecode
ImportError: No module named unidecode
removed151214
2014-03-20, 00:38
(2014-03-20, 00:30)sialivi Wrote: [ -> ]Getting the following exception with beta 3 and the latest script.skinshortcuts:
Code:23:27:55 T:5632 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
import xmlfunctions
Install script.module.unidecode
2014-03-20, 05:08
Hey Bignoid. Whenever my secondary machine wakes from sleep i get an error with library.data.provider. I use mysql so maybe after it wakes up the plugin takes awhile to re-associate. but it happens every time.
Also is bannerplex and episode list going to make the cut? I know bannerwall is fairly close to bannerplex.
2014-03-20, 05:21
(2014-03-20, 00:38)Unfledged Wrote: [ -> ](2014-03-20, 00:30)sialivi Wrote: [ -> ]Getting the following exception with beta 3 and the latest script.skinshortcuts:
import xmlfunctions
Non-realted question.. but what file in your addon controls the submenu items? I copied your skinshortcuts from what install of XBMC to another but it didnt carry over the sub-menu. It kept what i had on it pre-copy.
