2014-01-16, 08:23
My problem, when I go to Files/Music/Artist and select a Artist the submenu opens with the files from that directory along with image of that Artist. However if the '..' (which is the 'Go up one folder') then the image that shows is no longer the default go back image but is now a image of a different artist. It is that way for all my artist now and even worse when I scan a item to Library it takes that image and put it now as the image for that artist. This does not affect Albums, Singles or any other menu it only affects the Artists under the Artist menu.
What I have tried,
rebooting the system,
changing to default skin Confluence from Aeon Nox,
checked my directory folders to make sure that image is not somehow under that artist(s),
under userdata - deleting guisetting.xml, and advancesetting.xml,
under database replaced mymusic32.db with a previously saved copy prior to my screwup, viewmodes4.db. None of this worked so I updated XBMC from Frodo 12.2 to Frodo 12.3
During that update xmbc updated my library so now I have this image in Library mode as well, sighh. Even worse while in Library mode if I click on update Artist that this incorrect image shows the Update will not work. Example: Aretha Franklin when I click refresh under update artist, it only refreshes to the incorrect image. If I manually enter a folder image and fanart image for her then click Refresh it will return to the incorrect image.
I imagine this is all tied together somehow but I don't know how. My problem occurred last week after I went through my music library and updated Artist, after I was done I went to the side menu "Viewtype Settings" "Background Customizer" and changed background setup to fanart. I didn't think I did anything else although I must have, after a few minutes and realizing some images were wrong I changed that setting back to off and it hasn't been the same since.
This is a bit hard to describe and hope someone can decipher my mess.
If anybody has a fix that would be amazing!!!! I'm not excited about doing a reinstall
My o.s. is XBMCbuntu.
What I have tried,
