Full Version: Chose Standard Video Scraper
Hi there,
I'm pretty sure this has been discussed but I couldn't find the answer I was looking for.
To Import all my Movies into XBMC I used the Universal Movie Scraper.
Now, when I add new Movies XBMC always gets the Data for the new Movies using TheMovieDB therefore the Data is inconsitent. I am looking for a possibility to set XBMC to alway use the universal Movie Scraper but did not find it.
There must be a sinple way around this problem.
THX for your help.
See Media_sources (wiki)
So goto source you which to modify content/set content, highlight > Context menu> Set content and chnage from tvdb to Universal scraper....
Also note Universal scraper settings as you can select where it scrapes from which can be IMDb, TMDb, Trakt.tv and Rotten Tomatoes
