Full Version: How can I move selected posts?
How can I move selected posts from one (skin) thread to another?
You can't.
But we can do it for you, just tell us which threads/posts needs to be moved to which location.
You can't. Only Staff or "Team-XBMC Member"s can just tell them which post you want to be moved and what location!
Thanks. I was sure it was possible, at least while ago.
If I can't do it myself in the thread I moderate I sure won't be bothering anyone else.
Pecinko, I am pretty sure you need to be a forum moderator to do that and as far as I can see you never had that permission set.
I do understand that with two skin support subforums you are maintaining it might be useful for you to have moderation rights there. - I will see what I can do.
(2014-02-17, 10:27)Kib Wrote: [ -> ]Pecinko, I am pretty sure you need to be a forum moderator to do that and as far as I can see you never had that permission set.
i always grant skinners mod rights to their own skin subforum.
i'm pretty sure i've set those permissions for Pecinko as wel.
ah, maybe something went haywire then. I am checking access now.
EDIT:
My bad I looked in the wrong place - you are currently a moderator for both Amber and Quartz subforums.
You should be able to move selected posts from one forum to another as you have all those permissions.
